offenhauser c flow characteristics
My question is would you be able to put a carb on it in any positing and how would performance be effected? I am looking at using one of these on my kit...
It would have to sit like it is in the pic looking at the motor from the passenger side. The primaries are on the left and the secondaries are on the right.
The web site states it is a standard four barrel foot print.
"The twin DCOE Weber sidedraft system replaces any standard four barrel with a pair of staged 2-barrel carburetors.
Infinitely variable to flow any required cfm, this system comes pre-calibrated and ready to run on whatever engine you specify.
Not shown is the fuel pressure gauge and pressure regulator, which come with every system. Shipped ready to bolt-on and go. Available with your choice of any custom finishing options."
"Progressive slide is seen on carburetor at right. This allows your engine to run on only the primary 2-barrel carburetor (on the left side). When more power is needed, the slide makes contact with the scew on its lever, and the secondary 2-barrel at right is activated. Drive on only 2-barrels...with the kick of a 4-barrel on demand."
You can see it here... Home
1986F150six
03-31-2017 09:34 AM
300, 49, aode, carb, diamond, engine, ford, jiminglesecom, mustang, offebhauser, offenhauers, offenhauser, orientation, paddle, shift
