Changing antifreeze
Just changed mine. There was a plastic valve on the bottom driver's side radiator bottom that got a lot of the antifreeze out. Then there was a block bleeder in proximity to the oil filter. Apparently there's another block bleeder port above the starter but I wasn't too thrilled about removing the starter just to change the coolant.
I drained the radiator, then drained the block bleeder port I could get to, then filled everything up with distilled water, ran it, then drained the radiator again. Then fill a fair amount with 100% to compensate for all the distilled water left in the engine until you get the concentration you want.
By the way, my owner's manual (2005) makes a really big deal about antifreeze concentrations not being above 60% even though the rest of the world emphacizes 70% and I have no idea why. Might have something to do with Xerex.
BareBones covered the actual mechanics of it, but I'd like to add:
Look in the owner's manual for your cooling system capacity. Drain the entire system, flush it as needed, and drain it again. If you're going for a 50/50 coolant/water mix, put in HALF the capacity in coolant, and then fill the rest of the way with water. That way, you wind up with a 50/50 mix no matter how much water is left in the engine.
Of course, this assumes you can easily dispose of the waste and flush water.
