1996 f250 dash lights
Old 10-27-2010, 11:14 AM
Mrbiff's Avatar
Mrbiff
Mrbiff is offline
Hello. I'm sure this has been covered but I need advice/instruction on replacing the behind dash lights on my 1996 truck.
Any help or direction to a previous thread would be appreciated.
Thanks
Old 10-27-2010, 11:19 AM
BuckHammer's Avatar
BuckHammer
BuckHammer is offline
I have one out on my '96 F-250 and plan on replacing it soon, so I'm curious, also.
Old 10-28-2010, 02:48 AM
86F150302's Avatar
86F150302
86F150302 is offline
Here ya go.
https://www.ford-trucks.com/forums/8...-the-dash.html
LED swap is popular. I did it to mine a while ago. Really easy.
Old 10-28-2010, 03:25 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
This is pretty simple. Pop off the two strips on the cluster bezel. They match the strip accross the rest of the dash. There are screws behind it. After you remove those gently pop the bezel off. If you have an automatic you may want to move the shifter down. Removing the headlight **** is a little tricky. You need to use a small screwdriver or pick type tool to pull it off, there is a small tab on it that you need to pull towards you. After that you just remove the cluster mounting screws and tilt it down so you can get to the bulbs. I would replace all the 194 bulbs with long life bulbs for illumination, indicators, and warning lights while you have it apart. That way you don't have to open it up again anytime soon. Be careful not to damage the circuit board.
Old 10-28-2010, 07:02 AM
funnyfarmcrafts's Avatar
funnyfarmcrafts
funnyfarmcrafts is offline
did all 6 gauges for my 96 exp a couple weeks ago---i stuck with the standard bulbs, 2 pks were a couple $'s a pack... no sweat- they just twist out, I would at least do the main gauge bulbs all at once. I was down to only one still illuminating the dash....hard to see much at night, but the orig bulbs gave her 14 years of dimmer controlled lighting...didnt see a need to go led with that track record.
Old 10-28-2010, 01:05 PM
Mrbiff's Avatar
Mrbiff
Mrbiff is offline
Thanks...
for all the help. Looks like this place is a great resource. With a 96 diesel with 230,000 plus on it I can use all the help I can find.
Anymore detail on the headlight ****? Is the tab inside the slot in the ****?
How long will this thing run anyway??
Old 10-28-2010, 07:10 PM
TexasGuy001
The tab is in the slot on the ****. Its kinda hard to see.
Old 10-28-2010, 09:51 PM
86F150302's Avatar
86F150302
Old 10-29-2010, 03:16 AM
TexasGuy001
Thats a good illustration.
Old 12-23-2018, 11:54 AM
Jairo Orellana's Avatar
Jairo Orellana
Jairo Orellana is offline
Backyard mechanic
Hi guys i want to change my cluster instrument bulbs on my 97 7.3 250 but i don't know how many lights i need to buy for this project. Pls help
Old 03-29-2019, 05:30 PM
Wayne Toney's Avatar
Wayne Toney
Wayne Toney is offline
Hey Texas guy I was wonder I've been working on my 95 f250 my dash lights and cab clearing lights will not come on everything else will my turn signal and battery light and brake light on the dash works
Old 11-18-2019, 08:21 PM
jmpape's Avatar
jmpape
jmpape is offline
I know this way too late, but I replaced mine this weekend. There were nine for dash lighting and another five warning light bulbs
mikejack
04-03-2021 08:15 PM
rlay302
05-30-2016 06:29 PM
1996_powerstroke
01-31-2016 04:04 PM
1996_powerstroke
12-23-2015 07:30 AM
brian_06328
Electrical Systems/Wiring
08-18-2015 10:53 PM
Quick Reply: 1996 f250 dash lights
