F250 snow plow package how is the ride?
Just checked and I have x code springs on mine. I noticed that the truck sits almost completely level and I was pretty sure suspension was all stock. Wasn't sure why before, but does factory x code springs mean I have the snowplow package? I've seen people post that they got a copy of the factory window sticker, but I didn't see where to get it on the Ford site. Where would I find that?
https://www.ford-trucks.com/forums/1...e-springs.html
https://www.ford-trucks.com/forums/1...r-e99-psd.html
My truck has 3 leaf X-codes and I have no issue with the ride at all. To be honest it rides like a Cadillac compared to my old POS Ram.
My truck rides very nice. I was driving a '78 F250 before this. This one is MUCH easier on my back.
I ordered my truck with the heavy service suspension package. This included higher rated springs....would these be the x rated...i did not read my door tag yet.
I just bought a new 2010 F350 with the 5.4L, it's got the snow plow package, and the slide-in camper package. The suspensison does not give much at all, it's a pretty stiff ride...much stiffer than the Ram 3500 Cummins I traded in. The sticker has a "10600 GVWR package" listed in the options. The wife hates riding in it and complains constantly.
Maybe yours will be a bit smoother ride since the diesel engine is so much heavier....
leaf springs
my truck is a 2001 f250 diesel sc and it has 3 leaf, leaf springs up front. i read somewhere that x code springs were only 2 leafs, is this true? my certification tag on the door is gone but it has the other sticker to tell the gross weight of vehicle and it says 4800 lbs. up front. bought the truck used so i dont know if it has plow prep pkg or not, was needing to know cause i was wanting to put plow on it and needing to know if it will handle the plow
Why does it help in towing? Seems it would make it worse, especially with the front end higher than the back end (like on my new 2012 F-250). Disappointed it is actually "raked"... sloped to the back (when hook my 5th wheel trailer on, it drops even further. And substantive load puts the "headlights in the sky"... what happened to real trucks, where when you put a load on it, they became level!!
Mine also sits a little higher in the front! I thought something was off in the suspension until a little research showed me it was because it came with the snow plow package!
Last time I checked the diesels came with 6000# springs regardless of plow package or not. I could be wrong with the newer trucks. If you have 6000 front end weight listed them I am right (this time anyways.)
#28
Am adding air (bags) springs... with compressor, remote control... I guess this will substitute for the blocks? Or, should I add the blocks, too?
Sure would like to add some load capacity to this 250... make it into a 350, in the rear, if possible. The snowplow package in the front seems to essentially make it 350 in that end?
Dealer/suspension guy tells me the 6.7L Diesel 250 and 350 are essentially identical, drive train wise... just differences in the springs (mainly rear), suspension?
#29
350 blocks: Sorry to be not informed here, but am not familiar with the term "blocks."
They're referring to the blocks between the leaf springs and the axle on the rear axle. The F-350 has taller blocks than the F-250. They aren't going to change your capacity but they will make the truck sag a little less under load.
#30
And raise it slightly higher than the front. That way when you hook up a trailer or carry a load it sits more level which is better!
