has anybody blocked the engagement valve toward the spring on the 4r100. I here it will speed up the time it takes to go in to forward and reverse. If so how much efect doeas it have. I am pushing 5 seconds for reverse engagment.
the reverse clutch pack is .020", as well as the direct clutch. I was able to get the coast clutch so that it just wiggles. So all three clutches are tight and the air check is perfect. It also has a new pump (not a reman), before I go back together with this unit I thought I would ask about that valve first.
