Tunes on DP Tuner F5...
Have 13 tunes on the chip but 95% of the time is 80 Econo, 120 Race, 80 Tow personally.
You must tow really heavy to need that low of tow settings. I just ordered a f5 and got high idle,stock,60 tow,80 econo,120 race. I haul a tractor that gross with truck weighs about 25,000. I hope the 60 tow is not to much for it but stock it's gut less and can barley get to 65-70
I have 12 and use just a few, but love knowing the rest are there. My main ones are the 60 and 80 econ tunes. Both are great, but the for me the 60 is a little cleaner running, but will still make smoke when I get on it. The high idle will be put to use more as is cools down. I use my tow tunes when towing because of the shifting. the higher tunes are being used less as the fuel prices increase, but still see their fair share.
Yes, or he did for me. it's called the 140smoke. I have the 140x and the 140smoke and both are strong, but the smoke tune will roll smoke at low rmps and speeds, it will heat things up in a hurry when you stay on it.
My advice is to call Jody and tell him what you want, he will help you decide what to get, then let your wallet set your limits.
Yes, some heavy towing here. Forgot to list my decel tune. But I tend to be more on the conservative side. My truck is tagged for 24k so I have to stay under that. When hauling a couple of tractors, I stay in 40T. I can't say that it didn't have enough power stock but now it is so much better, especially the transmission. No shifting on virtually any hill in overdrive.
All the prices are listed on the DP-Tuner website(link in Signature). Not sure if the extreme smoke is listed, but I'm sure it's the same price. I've had mine for a while and really don't know what I paid for them.
I also have the decel tune and it's well worth if if you tow much at all.
I'm thinking bout high idle 1500, 80hp tow, 80hp econo, 120hp performance, and then my extreme smoke if possible.
Bottom line is still, you need to talk with Jody and let him help you decide what to do.
