another oil leak - BIG plug on HPO rail this time
Well, the oil pan leak is scheduled for repair between Thanksgiving and New Years - gonna pull the engine (aaaargggghhhh!!) and hopefully fix it ONCE...
On this trip to Houston, I discover a leak on top of the engine. It took 1.5 gals of oil to get 1000mi... Not quite a gusher - yeah, I've had THOSE before - but certainly enough to make a mess of the underside of my truck and all over my 5ver!
So I finally get a chance to clean it all up, and the leak is from the large allen-head plug on the the HPO rail on front of drivers-side head. I can see some 'sealant' on this plug and I wonder why its there.
Doesn't this thing have an o-ring behind it???
I guess I'll call Bob tomorow and get new o-ring(s). Looks like I'll be here at least until the weekend for work anyway........ (and helping zooman put new injectors in his truck - actually, we pulled his old ones out this afternoon!! )
Received 3,652 Likes
on
There is a big, strange shaped o-ring on each plug and requires LocTite 277 to seal it up. Allowing enough time to let the LocTite to cure is critical for a long term repair, don't rush it.
Plug O-rings
Once in a while the plug will crack during the removal process but it is rare.
Plug and O-ring
Plug O-rings
Plug and O-ring
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
Seriously, I should be headed home this weekend - I can prolly swing by if ya think I can help.
Thanks Bob & Clay, I ordered the orings (from Bob) right after I typed this post last nite.
Ray, I'll be in touch!! I really appreciated your technical (and moral) support last time I had my engine out...............
creator
03-28-2016 07:39 PM
John Irwin
09-11-2012 08:11 PM
