upper and lower ball joints on my 02
Old 10-25-2010, 10:13 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
You can expect to pay about $300- $347 for a parts kit depending on a OEM or aftermarket
Here are some kits:
OEM!! www.partsguyed.com
You are going to need to make or borrow an axle seal installation tool.
Also, if your u joints are looking tired,now is a great time to replace them.
The link provided above is a great tool.
Old 10-25-2010, 11:32 PM
helifixer's Avatar
helifixer
helifixer is online now
Received 3,628 Likes on 1,119 Posts
moog has been lasting good, be sure to follow the torque sequence or they will bind. on the ranch trucks 50,000 to 75,000 miles and they are gone.
a full front end including spring bushings ball joints and tie rod ends is about 5 hours
Old 10-26-2010, 08:12 AM
USAF CCM's Avatar
USAF CCM
USAF CCM is offline
I was unsure as well.....but did both sides upper & lower. You will need the ball joint press (my auto hobby shop had one). Perhaps a local auto parts store has one for rent.
The 45 degree zerk WILL snap off, take this from personal experience. V/r Les
Old 10-26-2010, 09:10 AM
th67ss's Avatar
th67ss
th67ss is offline
For the upper ball joint zerk use a 90*, all you need to do is grind down the top of the zerk a little so the u-joint doesn't rub on the thing.
I had mine disassembled (both sides) in about three hours plus the old BJ's (biggest PITA) out. Had a shop that I deal with all the time press the new one in and check my wheel bearing, u-joints and knuckle seals, which I needed new knuckle seals because one was bad. This was the first time I've ever done BJ's and it wasn't that bad.
I would go with partsguyed's kit that is a heck of a price for everything, plus their OEM
I would recommend having a pickle fork, nice torque wrench, pry bars, breaker bar, and some jack stands plus all the right sockets.
...Tom
Old 10-26-2010, 11:56 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
im sure i can do this easily. i just looked under the truck and noticed that the housing has wet dirt oil build-up on the left side. is the seal on the outer housing ?
or is it in the third member ?
Old 10-27-2010, 01:24 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Here's an additional reference guide for doing this job:
Super Duty Ball Joint Replacement
Pop
Old 10-27-2010, 01:53 AM
Downshift76's Avatar
Downshift76
Downshift76 is offline
I did mine not too long ago and I put 90* and left them on. I took my drimmel and ground them down enough to clear the U-joints. Knowing what I know now I would do it again. Check your axel seals, they were hard for me to find and a hugh PITA. At one point I was sure I would be looking for a new front end.
Old 10-27-2010, 05:20 AM
hammer65's Avatar
hammer65
hammer65 is offline
Check out what Racerguy posted.
https://www.ford-trucks.com/forums/3...ll-joints.html
I am 73 years old, and I followed the above, and did both sides in about 8 hours.
I was able to use a friends press. Some one posted about a seal tool made from 1 1/4 " pipe flange and an 8" nipple and an end cap to make a seal installer. Worked great.
I followed Guzzles thread on on bearing lube and resealing the ESOF.
Welcome to guzzle's Ford PSD Maintenance Web Page
Old 10-27-2010, 10:30 AM
th67ss's Avatar
th67ss
th67ss is offline
Sound like the inner seal is leaking? This would be a good time to fix that because you'll have the axle shafts out.
....Tom
Old 10-27-2010, 10:42 AM
mudmaker's Avatar
mudmaker
mudmaker is offline
I did both upper and lowers on both sides, inner axle seals and new bearing units on mine. Took about 8 hours total. If I ever have to do it again it wont take near as long. Not hard, just wish I had a shop with a lift!LOL!
Old 10-27-2010, 01:53 PM
jd3rdnoah's Avatar
jd3rdnoah
jd3rdnoah is offline
I just took my 2X4 DRW 2001 to have the front end lined yesterday. He said the ball joint were bad. Gave price quote of $375 . That includes the parts and alingment. Hope this helps.
Old 10-27-2010, 04:01 PM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
you might want to ask which brand of ball joints he is going to use for that price. sounds like the 10 dollar autozone ones......
  #28
Old 10-27-2010, 05:23 PM
F250_'s Avatar
F250_
F250_ is offline
I've already had a set of Moogs go bad after only about 30K miles, and the job was done by a good shop with knowledgeable mechanics.
After the two they did, I've done six other sets of uppers & lowers on three different trucks, but all were 2WD. I've got it down to about 4 hours for both uppers and lowers on both sides now, but again, that's for a 2WD.
As for which brand.... Moog is sworn by for a lot of folks. I've also used XRF ball joints (million mile warranty, but made in China), and have had absolutely no trouble from them at all. The machining in the joint seems to eb closer in tolerance than the Moogs I've seen, and they're less expensive than the Moogs.
(XRF Chassis | Automotive and Heavy Duty Chassis Parts | Canada and Unites States).
I would suggest going ahead and installing dual adjustable camber bushings while you're in there, especially if you're going to be looking at increasing front end height in the future.
The total parts price for ball joints and camber bushings for my 2Wd trucks have run in the neighborhood of around $200-$225 IIRC.
  #29
Old 10-29-2010, 05:02 AM
vans's Avatar
vans
vans is offline
I paid to have mine done, I think it cost around a grand, also replaced one hub, that was around 115,000 miles, now at 130,000 and just replaced front u-joints.
Whether you do work yourself or pay I would prepare for extras
  #30
Old 06-11-2011, 09:25 PM
sand_fiend's Avatar
sand_fiend
have parts
Just got all my front end parts. So on Monday I'll start.
I'm going to try the XRF ball joint's, tie-rods and drag link kit.
I got new needle bearings just encase.
new inner axle seals from ford to Fix leak.
new diff gasket.
new hub seals.
new dust seals.
new yellow o-ring, ford.
new locking hub o-rings.
I bought the C press, ball joint installer.
With all the info and pictures of the removal and installation, Things should go great.
Need to check U joints while axle is out.
And , note to self.. ice the gears.. LOL.
Thanks for all the input guys..
I'm not going to rush this, so it will take a day or two..
I'll give you the feedback on the ball-joints and tie-rod kit.
Quick Reply: upper and lower ball joints on my 02
