Converted 1997 F-350 7.5 460 to Sequential EFI - Tuned with AEM - Dyno Graphs Inside
As some of you may know I converted my 97 F-350 with a 460 from bank-to-bank EFI to sequential EFI by making a wiring harness and wiring in some other sensors so I could use an AEM full standalone ECU on my speed density setup (saved me from having to convert to MAF)
Donor harness from a 95 F-150.
SEFI harness ready to be installed
Stock Honda MAP sensor installed
The finished product
First run it made 203HP and 321Torque
Second run I added about 4 degrees of timing and made 210HP and 329Torque
Third run I added 8* down low (went from 19* @600rpm to 28* @ 600rpm, then calculated over to 3500 where I'm running 35*. I kept it at 35* total as a previous with an added 2* didn't increase it at all) This is when I made 207HP and 341 Torque. Adding any more timing didn't help power so I backed it off to where it was and left it. AFR's were around 12.8 - 12.9 consistently
First run
Second run
Third run
First run
Second run
Third run
davewild
349
08-30-2020 10:17 AM
