low fuel pressure displayed
the last few night in nj have been cooler then normal and the past 2 times iv started my truck it has flashed low fuel pressure. the first time was remote started and the 2nd was me in the truck turning the key. can anyone give me a reason, or anything to check?
<embed type="application/x-shockwave-flash" src="http://static.pbsrc.com/flash/input.swf" style="" id="IMGTag-code" bgcolor="transparent" quality="high" name="IMGTag-code" wmode="transparent" allowfullscreen="true" swliveconnect="true" allowscriptaccess="always" flashvars="ipt=%5BIMG%5Dhttp%3A%2F%2Fi142.photobuc ket.com%2Falbums%2Fr117%2Ffatheadon1%2FIMG00098-20101023-0005.jpg%5B%2FIMG%5D&trk=image_code_click_FULLVIEW _IMG&width=175&height=21&color=#000000&border=#BDB DBD&cont=IMGTagContainer" height="21" width="175">
Per my 6.7 Diesel supplement page 37.
LOW FUEL PRESSURE MESSAGE
The engine is equipped with a low fuel pressure detection system. If the
message center displays: LOW FUEL PRESSURE the following
explains why and what to do:
• Cold start or cold operation (below 32°F (0°C): If this message
appears during a cold start or during cold operation up to 10 minutes
after the initial cold start, monitor the message center. If it disappears
and does not re-appear after the engine has fully warmed up, the low
fuel pressure message is most likely caused by waxed or gelled fuel.
Do not use alcohol based additives to correct fuel gelling. This may
result in damage to the fuel injectors/systems. Use an anti-gel additive
as listed in Maintenance product specifications and capacities
section in this chapter. The customer warranty may be void from using
additives that do not meet or exceed Ford specifications.
If the low fuel pressure message persistently appears after re-fueling
during the cold start and cold operation conditions defined previously
and then disappear when the engine has fully warmed up, consider
different fuel sources.
Maintenance and Specifications
37
37
I had this pop up yesterday (14 degree start) and the day before with a temp pretty close (it was 9 degrees this morning and is a blistering 17 right now). The "Low Fuel Pressure" popped up on the screen so I hit "OK" and it went away. I took it easy (as I always do on a start up) and all was fine. I have some PowerSource in the tank and just hope the fuel company did their job with the winter blend. No other issues.
Yeah, exactly- I use it too. Every tankful; the reason it worries me is the few explanations about why it's happening is being blamed on the fuel gelling, the conditioners should prevent this- so it nulls those explanations, which leaves us waiting for a better one.
