Where can I ask mechanical problems?
here is the problem we have, i posted this elsewhere and have no replies :(
2001 Ford F250 5.4 liter. Thats all i know as for details..
We can get the truck to turn over, and it will stay on as long as we do not let off the gas. it will also not start unless giving it a bit of gas. We did replace the PCV valve last night, that did help with a small odd noise. Also, when the truck is running, it has a very odd smell. any ideas what this could be....?? fuel pump, air flow sensor, and the air intake control are all suggestions that i have been given thus far.
Also, is there anywhere to find a manual with a labeled diagram to identify some parts under the hood?
on
I would check the IAC- idle air control. Might need cleaning/replacing. If you use the search and look up iac you will find a thread with pictures and symptoms.
You can use this picture from the V-10 to get an idea of where it is. https://www.ford-trucks.com/forums/5...rsion-v10.html
I've solved this problem twice in a 150 with a 4.6 once and a expedition with a 5.4 twice now i believe on each occasion i sprayed carb cleaner into the throttle bodies scrubbed some with a tooth brush and it fixed it. I have heard that carb cleaner can damage the sensors but i never had an issue
I cant even describe the smell, more chemical like than sulpher.. and it actually coming from under the hood, not the exhaust. I did go and get an Auto scanner today and will see if throws any codes tonight. we have sprayed the carb cleaner in there and thats when it did seem to start a bit better, but still died.. hope i have an update by monday.
thank you all for the replies, it has helped...
Ripemdry
52
05-25-2016 08:58 AM
Eagle460
08-25-2010 03:26 PM
