99 crew center console won't come out?
Old 10-22-2010, 12:33 AM
Broncodawg's Avatar
Broncodawg
Broncodawg is offline
I know, seems like lame problem, but the torq head screws that bolt it down to the floor just spin? No nuts showing through the floor above the transfer case that could be spinning. Prying up while turning, nothing, they just spin, but can not pull out to replace console?
Weird deal, anybody else have this problem? Scratching head!
Old 10-22-2010, 06:52 AM
crum71's Avatar
crum71
crum71 is offline
1/8 mile Oval Track
Have you tried going under the truck with a small hammer and tapping on the bottom of the bolts? Im guessing that the factory weld holding the nuts have broken and letting the bolts turn. I never had that problem with mine,but I know what your saying
Old 10-22-2010, 06:55 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Like Scott said.If the nut has broke loose put some visegrips on it and wedge the grips agaisnt something to hold them if you are by yourself.
Old 10-22-2010, 10:35 AM
Visseroth's Avatar
Visseroth
Visseroth is offline
If they are just spinning try sticking a pry bar under the lip of the metal for the center console, pry up on it and then spin the bolts. See if that helps otherwise like they said the weld could have broke from the underside. You could try and re-tack the bolts.
Old 10-22-2010, 10:46 AM
60RatRod's Avatar
60RatRod
60RatRod is offline
There is no such thing as a lame problem, Have you considered taking a 4" grinder to the bolt, get the console out of the way and then have a look at the problem from a differant angle. I have had those Ford clips that act as a bolt strip out on me before. I usually just replace them when they do.
BTW I like like your avatar pic
Old 10-22-2010, 11:49 AM
Broncodawg's Avatar
Broncodawg
Great replies, thanks. I have a nice Tuffy console that I could repaint and replace the kind of cheezy console that is in it, if I can get it out. haha!
I have the xlt buckets and separate console (wish it was the split bench, much nicer).
Can't see any nuts from under the truck. They would be above the transfer case, but seems to be double walled.
Dam bolt clips are likely in between and the installer over torqued them and broke all four loose. They won't torque back down either.
No way to get sawzall on the bolts, so might have to destroy the thing to get it off, and better be damm sure the Tuffy will work better.
60Ratrod, That's my 58 F1, factory v8, 4speed, converted to 4x4. Dry as a bone from the desert, but mere yard art right now.
Old 10-22-2010, 02:04 PM
60RatRod's Avatar
60RatRod
60RatRod is offline
Mine is a 58 and a rust free desert truck too. Right now its in storage in Las Vegas. Last time I had her out was April for Viva Las Vegas.
Old 10-22-2010, 03:13 PM
Duzitall's Avatar
Duzitall
Duzitall is offline
My 75 crewcab shorty 4x4 highboy is a rust bucket Runs great though We had a nice clean 1960 F1 until my sister totaled it on the freeway
Old 10-22-2010, 06:45 PM
F350-6's Avatar
F350-6
F350-6 is offline
Get a cordless (or corded) drill and put the bit on the end of that and try to remove them. Often times the high speed of a drill (remember to put in in reverse) will overcome the spinning nut and allow you to remove the bolt.
madjak
1999 to 2016 Super Duty
05-14-2012 09:02 PM
broncobran68
05-06-2008 06:19 PM
davisnw
1997-2006 Expedition & Navigator
11-07-2006 12:33 AM
hudson2816
Appearance & Dress-Up
01-18-2005 04:16 AM
dandg
Bronco II
19
11-29-2003 06:05 PM
Quick Reply: 99 crew center console won't come out?
