85 F350 Carb EGR
85 F350 Carb EGR
Hello,
My name is Jeremy and I am new to this forum. I am rebuilding the 460 engine out of my F350. I noticed that the carb has an EGR built in. I want to get rid of this but I heard that if I do, it may cause an issue with pinging or detonation. I have a non-EGR Edelbrock Performer intake manifold coming. Is there a phenolic plate for the Holley 4180 stock carb? What else would I have to do to be rid of the EGR so that my engine runs correctly without damaging other parts?
Thanks all,
Jeremy
Thanks all,
Jeremy
Welcome to FTE Jeremy!
There are 1" thick 4 hole phenolic spacers all over Ebay right now. Phenolic 1" 4 Hole 4bbl Holley Carb Spacer with Studs : eBay Motors (item 220685438903 end time Oct-22-10 21:08:30 PDT)
1'' phenolic 4 hole carb spacer kit,HOLLEY,edelbrock: eBay Motors (item 360311143852 end time Nov-16-10 13:48:51 PST)
1" PHENOLIC HOLLEY 4 BARREL CARBURETOR SPACER: eBay Motors (item 400165390326 end time Oct-23-10 21:58:15 PDT)
etc....
in my experience you will need to adjust both the 4180's mixture and your timing curve to keep from pinging.
etc....
Thanks for the advice. The new carb is a little out of my budget range as Ive had to buy one head and manifold already. Still waiting for the block to come back from being cooked and cleaned and bored. I will try blocking off the egr for now. Will I have to retard or advance the timing? I plan on rebuilding the carb so I will adjust the mix then. Thanks again.
Try just bolting a thin piece of aluminum can between the neck of the spacer and the valve itself if a $17 spacer is out of reach.... or just fill the port with silicone.
<a href="http://www.flickr.com/photos/24183730@N03/2341349490/" title="IMG_1895 by Jim_Urrata, on Flickr"><img src="http://farm4.static.flickr.com/3158/2341349490_3737e383a4.jpg" width="500" height="375" alt="IMG_1895" /></a>
Otherwise there's nothing to block off.
If you got the non-EGR manifold there is no hot exhaust gas port to worry about.
I fount it too lean in cruise and tip in. There's only so much adjustment available in the idle screws before it wants to load up at lights and such.
The annular boosters in the 4180 are great atomizers.
Look at the Flemworld site under '85 How To's to see more about the internals of the 4180 carb.
4180 Mods
Scotty J has distributor recurving instructions on his website.
Duraspark_distributor_recurve_instructions_index
The Crane Cams 99607-1 instructions delve into more tuning detail.
http://www.jegs.com/InstallationInst...70-99607-1.pdf
Hope this helps...
4180 Mods
Hope this helps...
as far as I know, the holley kit for a 4160 will work (maybe not just found that the 4180 gaskets are slightly different...). I did mine by getting a kit from Napa based off of the id tag on the carb, that is the best way to do it. If you want better gaskets, you could get a set of the holley blue ones fairly cheap as well.
I am fixing to rebuild another 4180 I got at the JY the other day for my 400. I was simply going to buy fuel bowls (to get rid of the vents) and a rebuild kit based off of the id tag. I was also thinking of using an aftermarket set of adjustable jets, so I don't have to tear it down to adjust it.
The tag on this carb is e5pe-bra but oreilly and auto zone could not find an exact match for this. Napa was closed at the time so incouldnt go there. Any ideas on where I can find a rebuild/renew kit? Possibly online? I did get one from Holley for the 4160 but have not confirmed if this will work. I will keep you posted.
At the point of rebuilding the smog carb you'd be better off even with a cheapy 4160 . You should be able to find them for $40 or less, + $20 for a kit. Better yet a 750 4150 VS or DP, though you'd be more around $100 total into that if you find a decent carb to rebuild. Those small smogger carbs leave a lot of power on the table with a 460 though. A 750 or 850 would be best.
Also since it sounds like you have it apart now, it would be a good time to port those heads.Even if headers aren't in the budget now, porting the heads is basically free if you have a few tools and some time. It'll pay off later, and even with log manifolds will help in power and MPG. The exhaust ports on these heads are terrible and it's just about impossible to make them worse than they are as cast. If you are interested in porting I can give you some pointers and I'm sure others can too.
The annular discharge boosters and vacuum secondaries make the 4180 a good carb when set up properly. It's not a carb that someone would go out and buy, but it's worth modifing in my opinion. The "smog" holes can be plugged or you can use different float bowls. Yes, it is okay to plug them because that is not their only source of airflow.
Although I do agree that a 460 would likely benefit from a bigger carb.
The 4180 can be desmogged easily. Plug or cap the vent tubes on the float bowls,
changed the two stage power valve to single stage type, and maybe increase the
primary jets by one or two sizes. Run the carb with the stock jets before you try
the larger ones because you may not need them. The annular boosters on the primary
side are what is great about these carbs.
Jeremy Kamutzki
106
01-31-2022 08:56 AM
Jeremy Kamutzki
09-10-2016 08:51 AM
lavatan
15
05-02-2015 03:30 PM
BuickGS
04-09-2008 05:40 AM
jeremyd72
08-30-2007 10:20 AM
