1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fuel filter stuck beyond belief
Old 03-18-2019, 02:51 PM
Richard S
Richard S is offline
Richard S has a good reputation on FTE.Richard S has a good reputation on FTE.
I just came into this truck a short while back ~ I'ed like to get it so I can count on it for longish road trips ~ the above was the first somewhat long distance ~ have been driving it back and forth between the upper and lower ranches ~ about 80+ miles ```
Yesterday I drove about 90 miles from the upper ranch away ~ if you know what I mean and it stopped and dropped me in Sacramento, California about 10 miles from my destination ~ not nice ```
It would be nice if it was the filter (fuel filter I replaced today) ``` I've a couple 1000 miles round trips I would like to make without worrying ```
Old 03-18-2019, 08:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
SuperDutyScaler is a name known to allSuperDutyScaler is a name known to allSuperDutyScaler is a name known to allSuperDutyScaler is a name known to allSuperDutyScaler is a name known to allSuperDutyScaler is a name known to all
Is the truck throwing an engine code? If it quit twice now the dash light should be on
Old 03-18-2019, 08:38 PM
super 6.8
super 6.8 is online now
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
Those fuel filters are supposed to be replaced every couple of years max. Don't blame the design when you should be blaming somebody's lack of maintenance (not necessarily yours).
Old 03-18-2019, 09:15 PM
Richard S
Died once ~ no trouble light on ~ I haven't plugged in a code reader ```
Old 03-19-2019, 01:04 AM
Qwazert
Qwazert is offline
Qwazert is starting off with a positive reputation.
Some good advice on here regarding how to use the quik-disconnect tools...here's my 2 cents.
I found that keeping pressure towards the fitting while turning the tool works very well for me. I have the cheap-o plastic ones as shown above.
I had to disconnect the line right where it goes into the tank on my last truck (GM) and despite being caked with crud and rusted, this method worked.
I'll douse it with WD-40 or PB if necessary.
Old 03-21-2019, 06:48 PM
Richard S
Greetings ~ Thanks for coming by ~ I did use WD-40 ~ anyway the filterer was dirty ~ pretty bad but I'm not convinced that was it ~ not throwing any codes ~ and no trouble light ``` Starts like a champ now ~ runs great
Old 03-22-2019, 10:05 PM
Richard S
Ok ~ happened again Fuel Pump ~ daughter said she will replace it for me and bring it up to me at the upper ranch Tuesday ``` This daughter is 18, beautiful,
works as a mechanic ~ trains horses and that's enough for any girl ```
Old 03-25-2019, 01:53 PM
Richard S
Replaced the fuel pump ```
JKessler00
11-14-2017 09:10 AM
bart f-350
06-16-2017 08:50 AM
Stewart_H
30
02-18-2016 09:24 PM
RVAExpedition
01-22-2016 07:53 PM
Homepride
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
08-19-2009 11:39 PM
Quick Reply: fuel filter stuck beyond belief
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
