explorer no start, low fuel pressure
2000 explorer XLT, 4.0L, OHV (VIN "X")---sitting for 15 months, engine turns over but no start unless 10 cc's of gasoline into intake manifold, then runs for 4-5 seconds. Fuel pressure of 5-6 PSI at fuel rail AFTER replaced fuel pump assembly and fuel filter. I can hear fuel pump come on for about a second with key on. Doubel checked fuses and relays for fuel pump and PCM, then again checked that engine would run briefly with gas squirted into intake manifold. Advice for next step??
Questions: 1) Could fuel lines be clogged after sitting for over a year?
2) Area driver's side next to spare tire, underneath jack storage, where return fuel lines are clustered (nuts are rusted and need to be sawed off)---some type of fuel regulator here? I thought fuel pressure regulator was on fuel pump assembly.
thanks for any help or advice.
Having said that, the fact is it will never start at 5-6psi on the rail.
But you can have it your way,
Pulse Damper
******** language=JavaScript> <!--var HIGHNONE = "";var LOWNONE = "";// --> *********>
Pulse Damper
<INPUT class=zoom_btn onmouseover="this.className='zoom_btn_ovr';this.st yle.cursor='hand';" title=Zoom onmouseout="this.className='zoom_btn_rdy';" onclick="javascript:zoomImage('/alldata/AFI~V22889562~C34322~R0~OB0~P2R0H~N/0/77993956/80829349/80829379/80829385/34853741/34857029/34858641/56208458/14621125/83221676/83221677', 1, 650, 527, 'zoomWindow', 'Pulse Damper', 'NONE', HIGHNONE);" type=button> ******** language=JavaScript> <!--var HIGHNONE = "";// --> *********> <INPUT style="CURSOR: hand" class=sized_for_print_btn_rdy onmouseover="this.className='sized_for_print_btn_o vr';this.style.cursor='hand';" title="Sized for Print" onmouseout="this.className='sized_for_print_btn_rd y';" onclick="javascriptrintImage('/alldata/AFI~V22889562~C34322~R0~OB0~P2R0X~N/0/77993956/80829349/80829379/80829385/34853741/34857029/34858641/56208458/14621125/83221676/83221677', 650, 527, 'printWindow', 'Pulse Damper', 'NONE', HIGHNONE);" type=button>
The fuel rail pulse damper located on the fuel rail reduces fuel system noise caused by the pulsing of the fuel injectors. The vacuum port located on the damper is connected to manifold vacuum to avoid fuel spillage in the event the pulse damper diaphragm were to rupture. (The pulse damper should not be confused with a fuel pressure regulator, it does not regulate fuel rail pressure.
Regardless of your misconception of hydraulic pressure regulation, this part on 4.0 L OHV engine is not the fuel regulator.
from an online source:
Pulse Damper
Pulse Damper
<input class="zoom_btn" onmouseover="this.className='zoom_btn_ovr';this.st yle.cursor='hand';" title="Zoom" onmouseout="this.className='zoom_btn_rdy';" onclick="javascript:zoomImage('/alldata/AFI~V22889562~C34322~R0~OB0~P2R0H~N/0/77993956/80829349/80829379/80829385/34853741/34857029/34858641/56208458/14621125/83221676/83221677', 1, 650, 527, 'zoomWindow', 'Pulse Damper', 'NONE', HIGHNONE);" type="button"> ******** language=JavaScript> <!--var HIGHNONE = "";// --> *********> <input style="" onmouseover="this.className='sized_for_print_btn_o vr';this.style.cursor='hand';" onmouseout="this.className='sized_for_print_btn_rd y';" onclick="javascriptrintImage('/alldata/AFI~V22889562~C34322~R0~OB0~P2R0X~N/0/77993956/80829349/80829379/80829385/34853741/34857029/34858641/56208458/14621125/83221676/83221677', 650, 527, 'printWindow', 'Pulse Damper', 'NONE', HIGHNONE);" type=button>
Pulse Damper
Pulse Damper
I was responding to the question of how the pressure upstream of the FPR works.
In fact if you read my post you will see that I instructed the poster to look for the FPR on the rail.... I certainly do not have any misconception of hydraulic pressure regulation.. and have 35yrs of engineering background to support.
75_92_95
1978 - 1996 Big Bronco
13
07-22-2015 08:47 AM
dananarama
11-21-2014 08:08 PM
nagataOSU
Modular V10 (6.8l)
17
07-09-2013 07:53 AM
CrazyMiracleMan
13
10-16-2012 03:35 PM
