Sponsored by: Real Truck
P0863 code help!!!!!
Old Oct 19, 2010 | 07:20 AM
gogator's Avatar
gogator
Unhappy P0863 code help!!!!!
Have an 07' F-250 6.0 diesel
Sounds like an old John Deere tractor for about 5 minutes after starting.
Been doing this for 2 years now when cold. Now it is happening after turning it off for a couple of hours even in the summer. Any suggestions????
Old Oct 19, 2010 | 08:45 AM
senix's Avatar
senix
I think that code is a TCM communications code? I think you are decribing what sounds like a fuel injectors issue to me.
Your injectors are fired with the help of Oil pressure.
I don't know enough about the system. Does the truck run better after an oil change? How often do you change the oil?
Old Oct 19, 2010 | 10:19 AM
dchamberlain's Avatar
dchamberlain
Can't find that code anywhere.
What type of oil are you using? Are you using Motorcraft oil filters? Are two more questions.
I think I'd want to know FICM voltages also.
Jodymarshall
Oct 15, 2023 06:31 PM
Bryzzle
1997 - 2003 F150
Jan 12, 2018 06:10 AM
XLmountainman
May 12, 2017 09:44 AM
Aune163rd
Aug 25, 2016 10:27 AM
AK429
16
Apr 13, 2005 08:45 PM
