Motor Swap
on
This is a pretty straight forward swap but there is an additional complication because your truck has OBD-2.. you need a complete 5.8 EFI motor from a '96 truck only. You would need a complete 5.8 motor anyway even if you had an earlier truck simply because very few parts transfer from the 5.0, but the OBD-2 system has some additional sensors that earlier motors didn't and that's why your engine choices are further limited.
on
The Lightning motor is sweet but you will need to add the crank sensor to it since that is one of the OBD-2 only pieces that it won't have. The sensor is two pieces a pickup mouned on the timing cover and a sensor ring that is attached to the the crank balancer. The 5.8 also doesn't have a knock sensor but simply omitting that doesn't seem to cause any issues.
And that's located at the bottom of the timing cover correct? Down by the harmonic balancer? Also, thought about goin ahead and upgrading the cam if I go with the 302. If I do so, are there any other mods I need to make? Also found a cobra intake on craigslist, how much will this add and what other mods will I need to make. Sorry for all the questions. This is the first efi motor I've messed with.
on
You have some cam choices available to you since this is a mass air truck, but be aware pretty much any cam you use will push the powerband further up the tach so you'll want to regear the truck to compensate.. especially if you have plans for larger tires. The stock cam is actually pretty good if you would prefer to maintain the stock powerband(0-4500rpm) and adding 1.7 rockers will increase the area under the curve.
The Cobra intake is different than the 5.0 truck intake but I don't know if it's an improvement, the truck version actually has larger runners with more throttlebody so you may want to consider keeping it.
