Leveling Kit ( post pics if u got one installed... before and after)
I have a 2inch leveling kit with 305x60xR18 nitto terra grapplers and 18 inch eagle alloys was curious of wat tire wheel combinations everone else was runnin *POST PICS*
thanx
RIGHT OFF THE LOT
Leveling kit and 33x12.50 nitto at's
thanx
RIGHT OFF THE LOT
Sorry y'all, but I am interested in your experience thus far with the Nittos. Seems like you all three have them. Coskid, you may have replied on my question before, can't recall. I am needing tires still and cannot decide. These were a consideration for the look and traction, but 98% of my driving is on the highway, so smoothness and treadlife are important to me. Thanks, and sorry again for going off-topic. PM me if you prefer. THX
Also, Quack, looks like you have the 35" size, right? How's that working for you? I have 33" and was considering the larger size. What gears do you have?
I have the 275/65/20 which works out to a 34x11x20 I believe. They fit awesome with no rubbing and no trimming to the truck. As far as gears I have the 3.73 LS. I wish I had taller gears with these tires due to some power loss, however with the Banks Stinger system I gained back most of the power from the lift and bigger tires.
I need a AAL or block in the rear though since the ARE shell weights the back down.
As far as mileage, I have over 27,000 miles on my NTG's and they still look new. I get many compliments on how they are wearing. I rotate every 6,000 miles and balance every 12,000 unless needed otherwise. I also run 52 psi in the front and 50 psi in the rear. Being E rated for 80 psi I like the ride at these pressures. The ride is amazing and on highway manners are superb. I would buy these tires again in a heartbeat.
Hope that this helps you. By the way I paid $250.00 a tire for mount and balance here in Ol' Virginny at a buddy's shop. He also installed the level kit and Banks system for me.
i got my nittos for right around 1000 and they are 305x60xR18 which is a 33X12.5 and the only thing they rub on is my mudflaps which im thinkin bout taking off any way since they arnt doin nothin and cause the tires stick out 2.5 inches past the fender lol thinkin bout some pocket flares or extend a fender flares havent picked between the too but prolly go with the pockets... hope u get the nittos i think u like the look and the ride ....
Why yes it is....good eye there. Brian is a buddy and I only use his duck calls. I have a Original in cocobollo and a Swamp Bore Hybrid in green curly maple with a acrylic stopper.
Hands down the best calls I have ever used.
