CTS/CS capabilities/limitations on the 09-10
If you're considering an Edge (or Gryphon) CS/CTS, please read the following e-mail chain.
The ones we are working on are the ones I listed bellow. At this time these are the only ones we plan to release.
Edge Products Technical Support
1080 S. Depot Drive
Ogden, UT 84404
Toll Free: 888-360-3343
Local: 801-476-3343
Tech Fax: 801-337-2198
Email: tech@edgeproducts.com
http://www.edgeproducts.com/
Sent: Mon 10/18/10 10:41 AM
To: Edge Tech
Subject: RE: Edge Products Contact Form
Thanks for checking.
FYI, the 09-10 F150 CS/CTS already has these options:
Speed Limiter
Tire Size
Gear Ratio
So Edge isn't working on these and there's no plan to?
WOT (Wide Open Throttle) Shifting
Standard (Std.) Shifting
Shift Firmness
Timing Adjustment
AVG MPG PID (not instantaneous)
Sent: Monday, October 18, 2010 12:32
To: XXX
I did some checking and turns out we are working on a few custom options for these trucks. The customer options that will be available are:
WOT Fueling
Idle
Rev Limiter
Speed Limiter
Gear Ratio
Tire Size
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
Sent: Monday, October 18, 2010 11:13
To: XXX
(this text is from another e-mail he sent after sending the first):
That email was explaining our new Maintenance Manager that will allow you to set reminders of when to do specific maintenance procedures on the truck. That is what that email was about.
I'm not sure where you are getting your information from but at this time there are no plans for any such update on the schedule. Currently the Evolution does not program the truck's TCM therefore we cannot change the shifting characteristics of the transmission. We are working on being able to program the TCM of the truck but we do not have a timeframe of if/when this will happen.
Let me know if you have any additional questions.
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
GR
*** Due to the large volume of e-mail we receive, PLEASE include previous e-mails when responding. This will allow us to read the complete dialogue in one message and will result in quicker responses. Thanks! ***
________________________________________
Sent: Mon 10/18/10 8:56 AM
To: Edge Tech
I’m sorry, I guess I wasn’t clear.
I heard through the grapevine (someone received an e-mail from Edge and posted it on F150online.com) that there was a big update coming for the CS/CTS to add features for the 09-10 F150. This update was supposed to come out in October.
I’m hoping this rumored update will add a number of the missing features (missing as in they are available for the 04-08 on the Evolution), such as:
Shift Firmness
Rev. Limiter
Timing Adjustment
WOT Fuel
AVG MPG (not instantaneous)
If the October update is not going to add these features, when does Edge planning on adding them?
Thank you.
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
To: Edge Tech
Speed Limiter
Tire Size
Gear Ratio
Shift Firmness
Timing Adjustment
To: XXX
WOT Fueling
Idle
Rev Limiter
Speed Limiter
Gear Ratio
Tire Size
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
To: XXX
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
GR
To: Edge Tech
Shift Firmness
Rev. Limiter
Timing Adjustment
WOT Fuel
Thank you.
