aftercooler boot popped off, twice.
we have an F-450 ambulance chassis w/ the 6.0 that had the after cooler boot pop off twice tonight. It's the one right after the turbo, before it gets to the aftercooler.
Is this a sign of a bad problem ?
Or just a loose boot ?
Please advise.
Please advise.
It's a common problem caused from oil that is saturating into the boots from the CCV system.
You just have to degrease the boot good or it will keep slipping off, I sprayed some starting fluid on my boot and on the turbo where the boot attaches to get rid of the oily residue, then reinstalled the boot and it's been fine for over a year now!
I just had the same problem. I held up the tube with a zip-tie to get home. Bought a new blue 40 degree coupling.
Going to build a brace bolted to the alternator bracket to help suspend the tube which is what I think accerates the problem.
What are the clamps to be torqued to and should the tube side be pushed all the in to the end of the taper before tightening...Thanks
beauboy
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
10-11-2007 10:07 PM
WIREPULLER
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-17-2005 07:02 AM
Spdalit
08-01-2002 11:51 PM
