how to check fluid in e9ta ca transmission
it is a 5 sp manual with OD, tower shifter. (e9ta ca) also have a threaded hole on the drivers side of the transmission that has nothing in it right where the transmission bolts the motor. the threaded hole is close to the top of the transmission. what is this hole for?
That is the mazda M5OD-R2 transmisson. It is NOT the ZF as stated earlier, the ZF was only an option in the F250 and F350s. I told ya that e9ta ca means nothing. There is a plug on the side of the trans body about 1/2 way up on the drivers side. I dont know what hole your talking about, possibly for a clutch setup that you dont have
Yea I considered that but in a truck thats several years old now, what was offered "Stock" for this generation truck might be rather meaningless now, at least to a degree. A ZF could have been swapped in at any point dumping a toasted mazda.
"e9ta" ca does suggest a ZF, not a mazda so I went with that until more info was given.
E9TA is a generic prefix for a part number (or is engineering number the correct term?). E means 1980's decade + 9 is the year 1989, T is for pickup truck/bronco, and apparently A stands for light truck engineering. Without the rest of the part number, that prefix could be used on a whole truckload of parts that were assigned a number in 1989.
All the ZF's in 1989 had the E9TA prefix and the same part classification number, with different suffixes - CA isn't listed: http://www.zf.com/na/content/media/u...ion_Charts.pdf
accent2010
Escape & Escape Hybrid
03-23-2017 08:36 AM
fr420
08-04-2016 08:57 AM
iwals
11-08-2010 09:31 AM
