Yet another 351M-to-400 build
#76
<param name="movie" value="http://www.youtube.com/v/6SMekIGDWRw?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/6SMekIGDWRw?fs=1&hl=en_US" type="application/x-shockwave-flash" width="560" height="349" allowscriptaccess="always" allowfullscreen="true"></embed>
#78
If tim meyers sells .060 pistons, they I would say its probubly okay. I know its best to have the block sonic checked to be sure its good, but having a good cooling system should help out. If its any ease to your thoughts, I have a 89 gmc, with a 388 stroker, which is a 350 2 bolt main bored .060 over, which is not recommended on these either, and it runs cool, and I push 430hp and close to 500 ft lbs of tq and its holding up. It sucks when people overbore engines in the beginning LOL, so they can't be rebuilt without sleeves. If you could find another block at the junkyard, I would do that. See if you could get one for like 100.00 with exchange. Looks like you allready have the intake and carb. The exhaust ports on the heads could use some porting to the roof of the ports. Thats what I had done on mine, and without headers it runs real good. How big of a cam are you looking at. I have the elgin version of the performer cam and it seams to work great. With the amount of money it looks like your going to put into this, I would look for another block. How much ridge did it have? There should be a buildup of blocks lying around with so many people putting in 460s. Also make sure it isn't allready a 400 since its been rebuilt.
060".
popstruck77
16
01-10-2021 11:12 PM
honkytonk
08-04-2007 11:12 AM
crawlfish
02-20-2005 08:24 PM
