What to do if the stud for a tie rod turns wirh the nut?
Hello All..
A little Help Please, I have2003 F-250 SD 130+miles.
Im trying to remove the Passenger side Ball Joints Got almost everything Off and im at the nut for the tie rod end from the knuckle. The Whole Stud turns??? What can i do Anyone???
Thanks Jay
Thanks Jay
I replaced the whole tie rod. The joint is not serviceable.
When I did mine the joint would spin no matter what I tried. Pickle fork, weight, turning the wheels, etc. I ended up cutting across the nut about 1/8" from the knuckle.
When it was about 2/3 way through the cut I was able to break it off with some careful hammer blows.
IIRC the replacement tie-rods and connector were under $150.
---Nailer---
---Nailer---
