I put an alternator into my 7.3 the other day. no charging. I test the batterys and they are good. check B+ at the batterys, 12.35. Test at the back of the alternator, 12.35. talked to a friend and he told me to check the light green/red wire coming out of the alternator for B+ voltage. I get 0.0 on the meter. Does anyone know where the LG/RD wire connects in the 42 pin cannon plug and on the PCM connector? Thanks for the help.
sorry, it is a 2003 E-450. I did some searching on here and found diagrams of the two bigger fuse/relay boxes. Neither looks to have anything labeled for the charging system
Started tracing the LG/RD wire. Found a small cannon plug connector right by the oil fill. Bad connector there. Butt connected and heat shrunk the wires together, and now we have charging!!
