at a loss to diagnose loss of compression
I have a 1993 ford f150 with a 5.0 it developed a dead miss on one cylinder and has 0 compression on the cylinder....using the hose from the compression gauge I can not blow air into this cylinder but can suck air through it .....any ideas here?
I am by no means a mechanic but I have done a few rebuilds ...just dont understand what is causing this one intake valve stuck open maybe?It seems that since I can not blow air into the cylinder it is holding compression since it can be pressurized this way,so I assume it is not a burnt exhaust valve or air would just blow through with no resistance.Thge same I would assume of the compression rings if they hold pressure blown in through a line in the plug hole then they would not cause 0 compression ? right?
A vacume applied acts as if its wide open to the outside but can taste gas fume this way...
cyclone-429
01-30-2015 04:39 PM
TexasMarkIII
07-30-2013 12:28 PM
dufrain
08-30-2003 07:27 PM
