Sponsored by: Real Truck
4r100
Old Oct 13, 2010 | 06:47 PM
dieseldude1971's Avatar
dieseldude1971
4r100
Got the transmission rebuilt, installed the tugger kit and the boost valves. new torque converter. everything is great, I love the shift, but it sure takes its sweet time going into reverse. Once it engages it is all there, but it takes a good 3-4 seconds to take hold. Any ideas, or is this normal.
Old Oct 13, 2010 | 07:27 PM
JonathanN's Avatar
JonathanN
Noticed that with my valve body... everything BUT reverse is quick. I wonder why?
Old Oct 13, 2010 | 07:54 PM
Fordfanatic4life's Avatar
Fordfanatic4life
maybe the solenoid takes to much line pressure to overcome ?
as in a spring thats to stiff ???
just guessing here..
Old Oct 14, 2010 | 09:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That sure is a guess. What do you mean? I can't figure out how anything like that could possibly be happening inside the transmission.
My guess is that either there is a problem with the reverse clutch seal, or the clutch stack, or you're impatient. Reverse is always slow on a 4R100. Have you timed the reverse engagement with a stop watch?
Old Oct 15, 2010 | 10:20 AM
dieseldude1971
The three little bolts are tight, the cluch pack air checed perfectly. It seems to take twice as long as any other, but most people seem to think it is normal, so I will just leave it be.
Old Oct 15, 2010 | 11:51 AM
dkf's Avatar
dkf
Is the tugger kit supposed to make the forward reverse shift quicker?
IMO tuning is a must with a VB, the VB only addresses the mechanical side and leaves all the sluggish stock parameters.
Old Oct 15, 2010 | 12:36 PM
dieseldude1971
The kit never says (that I saw) it makes forward or reverse quicker. That was not my reason for putting the tugger kit in. I love the way it makes the trany shift. I was just hoping it would make it a bit quicker in reverse.
parkland
May 1, 2012 12:41 AM
ncfirefighter46
North Carolina Chapter
Jan 13, 2007 09:20 AM
460mudtruck
Offroad & 4x4
Aug 27, 2006 01:59 PM
4poco
1978 - 1996 Big Bronco
17
Jun 9, 2003 07:10 PM
crueljon
Jan 24, 2000 10:42 PM
