88 F350 to 4x4
88 F350 to 4x4
Hi everyone, just joined the site and have a question. This may seem like a repeat question but I didn't want to hijack Dutters' thread as his question dealt with a 1/2 ton. I was wondering if the front drive axle from a 95 F250 would bolt into an 88 F350. Both trucks are manual 5 speeds. The F250 has the 5.8 while the F350 has the 7.5. An auto wrecker told me a couple years ago that it would be pretty much a bolt in as both are independent front ends. The 95 would be a donor vehicle so all parts are available. Anyone here with any experience on this?
Thanks
Thanks
no experience on my end but i have read and read on it because when i graduate i plan on doing this, but everything i have read and reasearched shows that it is a bolt out, bolt in operation.. when i do it i'm planning on just getting the tailshaft off of a m5odr2 that acepts the transfer case..
also i have found that the trans, case with the floor shift is the easiest to swap in, and i prefer the floorshift over the push-botton..
also everything you read in dutter's thread also applies here..
and welcome!
and welcome!
Thanks for the reply and welcome. I was hoping it wasn't going to be a major transplant. I've been eyeing an 88 F350 Lariat Crewcab that a neighbour a few miles away has had sitting for a few years. Only has 180,000 km (about 112,000 miles) on it, all highway. Only problem is it's a 2 wheel drive. I was inquiring about the conversion when an auto wrecker mentioned it would be a straight swap with a 250 front axle. Then other things came along and my plans changed a bit. Now he wants to sell it and he has a 95 250 with a deck on the back I want too. The 250 is rusted and underpowered for the weight it would be carrying. I can get both trucks for less than $4,000 so now the wheels are turning again. Would the 5 speed trannys be the same in both trucks so I could just swap tail shafts? I don't really need a 4X4 but they're really handy in the winter here in Central Alberta. If anyone else has any more info they wish to share I appreciate all points of view. I have until the weekend (Oct. 16) before they advertise locally so I should make a decision by then. Thanks again.
Snow Bound
25
01-30-2015 12:28 PM
Asterixx
23
06-20-2007 10:51 AM
