Better Starters
#76
Just two quick things:
1) After pulling the Chinese DBE after 11 months, those bolts had not budged. I used Loctite and it did its job just fine. I am not at all worried about bolts backing out.
B) To move the truck this morning for the work, I cranked on that Mitsu unit. I did not think it would start, but it did. Reluctantly. This is the second or third Mitsu type I have had. They start out much stronger than they finish a coupla years later.
Thirdly) I lied about having only two things. It's very tough to find out which starter units are made where these days. This made it clear that I had to seek out a known solid electrical motor. The Denso products have had a very good reputation over the years and have been used in racing and heavy equipment. I have no compunctions with using their products and it should be acknowledged that the Japanese make some pretty good stuff.
That said, I am keen on MiUSA wherever possible, so I would like to know more about the Quick Start products.
#78
These two companies appear to be a great option for starters and alternators.....and offer American made products!
Ford Power Stroke 7.3L 6.0L 6.4L 6.7L Diesel Type High Output Large Case 6G Series Alternators
Nation Starter & Alternator,Tractor Auto,Marine,Truck,Small Engine
BTW, if you haven't seen my thread about engine heater and won't start. I'm thinking it's the batteries along with most advice.....still can't get it to turn over! Sorry for the hijack!
#80
Here is the old Mitsubishi unit:
YouTube - Mitsubishi starter.MTS
It was a ton better when it was new. Fast starts and all. After less than a year or so, it would randomly go slow and then it went slow all the time like this for a few more months. Though it seems like it's going to fail, it would always eventually start. I was always looking around to see if any truck guys were watching and chuckling. This is at least the second Mitsu I have had with this truck. The first one had the exact same condition.
Here is the Japanese Denso:
YouTube - True Denso.MTS
Now it sounds exactly like a truck should when being started. The DB was very similar in sound, but not so similar in reliability.
I can do a starter change in under a half/hour now.
Hope this helps.
DS
Hope this helps.
DS
#81
Hope this helps.
DS
Hope this helps.
DS
#82
#83
My original 3-bolt starter with 200,000 miles still turns the engine over just like that Denso does, with the same start time.
As pathetic as your old one was makes me think that maybe only two of the four brushes were making contact, thus it was maybe running at half its rated power.
Pop
Pop
#85
Hope this helps.
DS
Hope this helps.
DS
Did it bolt right in?
Did you have to extend wires to make connections?
Did you buy this one from Larry B's ?
How much?
#86
#87
Yes, I bought from Larry Buck. He answered all my questions and was very quick with shipping. I am only an hour away from him, so it was at my house the next day. He even tossed a pair of disposable gloves in for the work. I didn't use them, but I appreciate the sentiment.
If Nations sells that exact same genuine Denso, it's cheaper than Larry's price. I'll give him the benefit of the doubt and presume that because of volume, he may not get as good of a deal from his supplier or something. I didn't find out about Nations until after I had already ordered. That's okay. Chalk it up to experience and I take some comfort in knowing that I supported someone local
#88
#89
Hope this helps.
DS
Hope this helps.
DS
