I'm looking at a 5.8 for my engine swap. My 5.0 has the crossover tube between the heads with the AIR valve on it. The stock 5.8 that I am looking at does not have one. Did they not come with it?
HD trucks typically didn't have the crossover tube it was plumbed into the manifolds instead, for the most part it was only the 1/2 tons that had a tube connected to the heads.
I think Ford had no real rhyme or reason for a lot of things. My '92 F350 had the tube, but it was removed, very obvious by the hardware used as plugs. Both of my '93 Lightnings had the AIR tubes in the headers.
I thought they did. The one I'm building at the moment had one(a 90). But I'm plugging the heads when I put ti together.
I would like to plug the tubes on the heads of my 92 f 150 5.8 ltr. What size plug fits the hole? My tubes are rotted out....expensive to replace.
Thanks
Thanks
