Help with 56 f100 brake and clutch pedal assy.y
Old 10-11-2010, 07:06 PM
rcook56's Avatar
rcook56
rcook56 is offline
Can anyone tell me how to remove the clutch and pedal assy. in my 56 f100? I have put on disc brakes and a firewall mount power booster setup and I need to remove the old setup. I can not figure out how to remove the shaft in order to get it out. Thanks in advance. I am new on here so I hope I have put this in the right place.
Rob
Moved to proper forum, thanks
Old 10-11-2010, 11:29 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Try posting in the 1948-1960 F100 Forum; hopefully someone there can help you. Good luck!!!
Steve
Old 10-12-2010, 07:44 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I will move this to the correct forum when I get home. On my phone right now.
Old 10-12-2010, 04:35 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Moved to correct forum.
Old 10-12-2010, 05:58 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
The info was provided from our princess in this post.
https://www.ford-trucks.com/forums/1...p-56-f100.html
Old 10-12-2010, 08:16 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Hi Rob! Welcome to FTE and the 48-60 Forum!
If you click on the link 56panelford poated above, there's a great exploded drawing there for you!
rcook56
04-17-2020 07:03 AM
nothercrash
12-10-2011 07:36 PM
yamagrant
10-05-2011 03:54 PM
Idaho Mtn Man
17
03-13-2011 11:51 AM
1bikenerd
01-26-2010 08:36 PM
Quick Reply: Help with 56 f100 brake and clutch pedal assy.y
