What is this part leaking oil?
It is leaking oil like crazy on mine, circled with arrow at it. Bolts were loose enough it was vibrating when I was looking for my oil leaks today. Only leaks when running.
http://www.flickr.com/photos/20557687@N03/5072100621/http://www.flickr.com/photos/20557687@N03/5072100621/ by http://www.flickr.com/people/20557687@N03/, on Flickr
Yup, that's the mechanical fuel pump, often called a lift pump. You have a gasket between the block and pump that is now oil soaked and possibly busted up from the rattling around so you might wanna replace it, though if it's still intact you could probably go for years without leaking from that spot again, haha. (been there, done that)
on
It would be my recommendation to replace the pump if you pull it to replace the gasket ...
Why, they are not super easy to get to and they are fairly inexpensive ~$40.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
jeffreythree
10-20-2010 03:18 PM
