1997 E4OD to ZF5 swap questions (NOW COMPLETE)
#61
#62
got ya, it sound like the fork but not sure, my truck was good and all t baring went out so put a new clutch and all in put it back to gather and it was just like what you said yours is doing, i spent the 35 bucks on a new fork for this swap, did you use 97 or your 92 tcase?? i have all myn ready 2go waiting on clutch and drive shaft to have 2 in added
#63
#64
got ya, so it would be a big help if i found wiring harness from a 96 insted of useing my 93, could save some time and messing with wires. my floor plates from the 93 and pedals worked, i am going 2 use 96 tcase and have and my short shaft has to have 2in added to it, my doner was a rcab not a cc so that sucked. hey wonder if wires from 96 460 5 speed will work???
#66
#68
#69
ok sweet, i have a chip and will have it reburned for a man should be ok there, the wires have been the only thing i was scared of, wonder if 97 will work?? brob be better off with 96 wires same year as the truck, do you know if a 460 is the same?? thanks man
#72
Brown falcon I am located in Vancouver WA.
I got the clutch pedal problem fixed all is good now, well its kinda noisy but i understand why, wish there was a fix for it.
another thing i thought of is it seems geared lower now? I thought both trucks had 4:11, but maybe i read the donor truck wrong
#73
Ok i got the truck all back together, I got lucky on the wiring everything worked, i didnt have to switch any pins. I had a lttle issue when i first tried to start the truck the 4x4 bar that connects between the shifter and the transfercase was to short so the transfercase was not in gear, kinda raised my blood pressure a little for a few seconds.
Originally Posted by GreaseMonky
It was a fairly simple swap in my opinion. pretty straight forward, truck drives good, i like they way it feels, cant wait to get a load behind it, it does seem to be geared a little lower then my auto, rpms are higher on the freeway.
Ii do have a few questions, I put new hydraulics in, but my clutch seems to release kinda high maybe about halfway? Ii ll look again later. And my downpipe is hitting the firewall and making it extremly loud inside the truck.
There is a rod that runs through the top of the pedalbox that the clutch and brake pedals ride on. Here too are more PLASTIC bushings. They can wear out and cause even more play in the system. $14 from Ford. If that is the case and it has progressed further then the pedalbox itself can become worn in such a way that the holes for those bushings and the rod can become "wallowed" out or the box even broken. Unfortunately the only fix for this is a new pedalbox.
If the clutch fork is worn or the seat for it is worn it can cause funny issues too. Most likely it is not your brand new hydraulics. Maybe you can warranty it and try but I bet it is a plastic problem.
And p.s. REDMAN Thanks for all the help, you made this swap go alot smother, I appreciate it alot.
...didnt think are auto wires would work,...
ok sweet, i have a chip and will have it reburned for a man should be ok there,...
the wires have been the only thing i was scared of,...
not sure going to go new hydraulics as well, but i have another set of 93 pedals as well man
#74
#75
You can also get pretty much a whole extra quart in by parking the driver's side up on a curb and filling through the fill plug.
