Tested for the breaking point on the early 4 spark plug thread heads - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Reload this Page >
Modular V10 (6.8l)
Old 10-11-2010, 05:55 PM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Yeah, by the way, I wasn't trying to shoot you down for what you accomplished
It's just that it's not all she wrote, if you know what I mean
Old 10-11-2010, 09:54 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
Originally Posted by Fordfanatic4life View Post
i think the only thing he was trying to prove was teh myth of any amount of overtightening with the early non-PI heads would pull the threads clean out..i think his examples clearly show even the worst heads on these motors have more then enuf strength to hold teh plugs in if checked and tightened properly..
ps THX bill for being nice enuf to test a set of heads out.. 3 cheers..
Originally Posted by DavidB View Post
As Art and Perry indicated, your test does not replicate real world conditions. Just to say that the head will withstand significant overtightening sitting cold does not indicate what will happen if the plug is overtightened and then goes through several heat cycles. Also What happens when the overtightened plug is removed and another plug is installed, even if installed correctly, it may not hold as it should due to damage that may have occurred when the first plug was overtightened.
I know you are not trying to shoot down what I did, I agree with everything you said.
All I wanted to do is show that the threads are not just going to strip at 25 ft lbs or blow holes in the hood running boost, and that they are not a weak design. This was just to back up my statments that they will always stay in if they are installed right. IMO, it proves just that.
I am very happy with the results, the heads did much better than I thought they would. What I expected was around 60 ft lbs the threads would give and the plug would just spin in the head.
My plugs will still be going in the same as always, 14 ft lbs with antiseize.
There are too many things that have to be taken into acount to ever think that you can come up with a better torque spec than Ford.
Next time I have a scrap head, I want to test something else kind of on the same note. I would like to see at what torque the plug goes past the spot it should rest in the head.
Old 10-11-2010, 10:35 PM
Zedrive's Avatar
Zedrive
Zedrive is offline
Zedrive is gaining momentum as a positive member of FTE.
Reps sent, Bill
Old 10-11-2010, 11:47 PM
bill11012's Avatar
bill11012
Originally Posted by Zedrive View Post
Reps sent, Bill
Thanks, right back at you
Originally Posted by Ricohman View Post
Its an F350. So what interval for the first plug change.
50 000kms?
100,000 miles on all the V10s.
I change mine at 50,000 becuase they seem to not perform as well after that, at least for my use. Thats 50K of high rpm towing and much more idle time than most, so they should last longer under normal use.
On the 3Vs the sooner they are changed the less likly they are to get stuck, or so I have been told.
Old 10-12-2010, 09:03 AM
perryg114
perryg114 is offline
perryg114 is gaining momentum as a positive member of FTE.
Thanks again Bill I feel better about having bought a V10 Excursion now.
Perry
Old 10-19-2010, 02:44 PM
Tonto57
Tonto57 is offline
Tonto57 is starting off with a positive reputation.
Thanks for all of the great information I just purchased a 2005 3500 dually 2 wheel drive with 56,000 miles and V10. I became very concerned after hearing rumors of spark plug thread problems. Are most of you sticking with the motocraft spark plug or I have heard that champion offers a one piece design that has less chance of breaking while removing. Any oppinions would be most appreciated.
Tonto
Old 10-19-2010, 07:12 PM
2000f350v10's Avatar
2000f350v10
2000f350v10 is offline
2000f350v10 is starting off with a positive reputation.
3 valve plugs
For the 3 valve V-10s, I do recommend using the one piece champion spark plugs. I know everyone says use autolite or motorcraft, but the only plugs I recommend out of my parts store for the 3 valves are the champions. I believe the part number is 7898.
Old 10-19-2010, 08:42 PM
perryg114
I would check into NGK. They are not cheap but they are a step above the American brands I have seen and they have alot of history in aluminum heads. I don't know about two piece versus 1 piece though. Go plantinum and chances are you won't have to replace them again.
Perry
Old 10-19-2010, 10:45 PM
bill11012's Avatar
bill11012
I have heard that the modulars do not like NGKs.
Old 10-19-2010, 11:13 PM
Tonto57
Tonto57 is offline
Thanks for taking the time to reply guys. I use NGK in all our atv and dirt bikes with no problems what so ever any idea why they would not work as well in Modular engines?
Tonto
Old 10-20-2010, 02:43 PM
bill11012's Avatar
bill11012
Tonto
It came up in a thread awhile back. I looked but could not find the thread.
After using NGKs the poster had a miss. He changed them for Motorcraft and it fixed the missing. A few others posted and made it sound like a fairly common proplem using NGKs in the 4.6/5.4 and 6.8 engines.
All I have is 2Vs and in them I use nothing but Motorcraft.
Old 10-20-2010, 05:20 PM
Tonto57
Tonto57 is offline
This is a great forum learning so much about the V10. I was ready to put a set of NGK plugs in the truck but will stick with motocraft instead.
Tonto
  #28
Old 10-20-2010, 06:36 PM
bill11012's Avatar
bill11012
Have you read the threads about the 3V plug problems, and removing them if they break?
  #29
Old 10-20-2010, 06:49 PM
Tonto57
Tonto57 is offline
Yes I have read the threads and it is pretty scarry! I have a thirty day warranty on the truck from the dealer where I bought it and really considering having them change the plugs just in case. Service Department says they have never run into a broken plug and if one broke it would be covered under the 30 day warranty. What do you guys think
Tonto
  #30
Old 10-20-2010, 06:55 PM
bill11012's Avatar
bill11012
How much do they want for a plug change?
Quick Reply: Tested for the breaking point on the early 4 spark plug thread heads
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
