Score a Deal on Nerf Bars in the FTE Marketplace
By -
Ford Nerf Bars
Save $165 on a set of brand new tubular running boards for your 2009-2014 F-150.
Modern trucks look naked without running boards, nerf bars or some sort of step system mounted below the doors, which is why so many Ford F-150 pickups are equipped with something to make getting in and out a little easier. The problem is that running boards and nerf bars can be pricey, but if you have a 2009 through 2014 F-150, you can get a great deal on a set of new-in-box nerf bars for your Ford truck.
The Description
This nerf bar setup for the 2009 through 2014 Ford F-150 was posted to the FTE Marketplace by billybobzia and his listing is pretty barebones.
Brand new, still in box.. matte black.. retail for $515
He also included a link to the product on the company website, along with an image of an older F-350 with similar step bars. As he points out, the items being sold are new-in-box, so he likely found a stock company photo of a Ford truck with these nerf bars and used that for his listing. The company also has pictures of the bars on a newer F-150, but there are no readily-accessible images of the 2009 through 2014 trucks.
Ford F-150 Nerf Bars
Item Details
As the link to the company website shows, these nerf bars for the 2009 through 2014 F-150 pickups are designed for the Super Crew configuration, with steps under each door and an extra set of steps to make accessing the front of the cargo box easier. They are made from carbon steel, pained matte black, with three-inch-wide steps extending from the tightly-mounted main bar.
For someone who wants a nerf bar setup that tucks up tighter against the body, these units from N-Fab are a great option and right now, you can save $165 via the FTE Marketplace.
Join the Ford Truck Enthusiasts forums now!
Comments ()
