REJOICE! O.J. Simpson’s White Ford Bronco FOUND!
Most of you will remember in 1994 where you were when the most infamous Ford Bronco ever was leading a low-speed chase in Los Angeles with O.J. Simpson behind the wheel. After the chase, the white 1993 Ford Bronco virtually disappeared for 20 years. Now, it has been found, and is apparently being saved as a collector’s item.
According to the Chicago Sun Times and Inside Edition, the Bronco is currently located in a garage in Northern California. It’s still nearly as pristine as it was the day that Simpson attempted to elude police.
Since taking ownership, the owner only has put 20 miles on the vehicle. He’s kept the tires in the trunk, and even siphoned the gasoline out of the tank and kept it thinking that it’ll all be worth something significant someday. I’m sure there’s a collector out there that would be interested.
What do you think? Is this something you’d pay extra money for, or is it something you’d rather just never see again? Let us know your thoughts and opinions in the comments below or over in our forums.
via [Chicago Sun Times and Inside Edition]
