Recall Alert: 2016 Ford Transit Connects Could Have Faulty Brake Systems
By -
transit_connect
According to a new recall released by Ford, about 1,900 2016 Ford Transit Connect vans might have a faulty and/or contaminated brake hydraulic control unit pump. The problem affects cars that were built between Feb. 22 and June 16 of this year.
In the recall, Ford explains that the HCU pump might have “metallic debris” in it. With that type of contamination, the debris could wear down and degrade the pump, causing it to work less effectively. And if the HCU pump isn’t working correctly, the brake systems like electronic stability control might now work correctly, which wouldn’t necessarily be the cause of a crash, but could increase the risk of it.
If your car is in this grouping, Ford will replace the pump for free. Call 800-392-3673 or go to www.safercar.gov if you’re worried.
via [Ford]
How to Guides
View All >
Roush Gives the 2024 Ford F-150 Visual and Performance Overhaul
Slideshow: Roush never disappoints when it comes to their takes on Ford vehicles.
Read It
Ford F-150 Lightning Purchase Turns Into a Nightmare for Owner
Slideshow: Luckily, the automaker was willing to help.
Read It
Top 10 WORST Excuses to NOT Buy a Ford Truck!
Slideshow: Ten worst excuses for not buying a Ford truck or SUV.
Read It
5 Reasons Why the Ford Bronco Is Experiencing a Sales Slump
Slideshow: For two straight quarters now.
Read It
