MUDFEST Ford F-350 Attacks Murky Water
By -
f350 18inch lift mud 600
This week’s Muddy video features a first generation Ford Super Duty F-350 attacking what might be a really, really big mud puddle or a very small pond.
In any case, this murky water is deep enough to swallow up most trucks, but when you take a big F-350 and add an 18-inch lift setup with some appropriate tires, no obstacle is too serious. Well, it was almost too serious, but the driver managed to work his way through the water after a trial run.
This jacked up F-350 starts by rolling into the water without the proper momentum to make it to the other side. Fortunately, the driver is able to back up and out of the water to make another run.
On the second run, the F-350 slows a bit through the deepest part of the water, but the big V10 keeps the truck digging through the mud and gets to the other side.
In addition to the suspension work, it sounds like this Ford F-350 has some work done to the powerplant, as it is a pretty healthy sounding V10 so crank up your speakers and enjoy!
Take a mud bath in the forum.>>
Comments ()
