TRUCK IT UP How to Install a Tow Hook to Your Ford
Even if you don’t go off-roading, you may find a set of hooks useful one day. Here is a step by step breakdown with everything you need to know about adding tow hooks for your Ford F-150 or Super Duty truck.
If you are an avid off road enthusiast, you probably already know that tow hooks are worth their weight in gold if your truck gets stuck in muck.
There is a reason most four wheel drive trucks come straight from the factory with these hooks, and that is because they are the safest tool by which to tie tow lines when trying to rescue a truck from mud, snow, or sand.
