BUILDUP A 1997 SCSB Ford F-250 Project
By -
FTE Build
Picking up a new project can either be one of the best feelings or one of the worst. Sometimes it is just exciting to think of getting a rig exactly where you want it to be, and other times it can be a stressful hurdle that keeps on throwing problems in your face. Regardless of how you feel when you pick up a new ride to work with, FTE member Brad (A.K.A. “Diesel_Brad”) seems to be quite optimistic about getting started on his 1997 SCSB F-250 build.
The ride is, to be more specific for all you knowledgeable people out there, a 1997 SCSB F-250 with a 7.3L engine, a 5-speed manual transmission, and four-wheel-drive that has 170,000 miles and a white exterior with a blue interior. So far Brad has already done a lot to help this rig, including removing the set of stacks that the previous owner had installed. He has also swapped the wheels and tires that were on his old rig to his new F-250, and they definitely look good! In addition to this, he has a Stainless Diamond Eye 5” exhaust en route!
Brad is clearly doing an excellent job with his F-250, and we’re very excited to see where it goes! Go check out his build thread and show your support!
Comments ()
