1988 F-350 460 to 300 Six Engine Swap: Awesome Thread of the Week
By -
Forum member begins engine swap but runs into trouble after spotting some cracking. But it’s nothing he and the FTE forums can’t remedy.
Ford Truck Enthusiasts is a solid source for comprehensive breaking news about classic and contemporary Blue Oval trucks, but we’re equally proud of the wide-ranging, infinitely interesting forums that our members and visitors continue to make one of the most invaluable sources for virtually everything related to Ford trucks. Whether you’re looking for advice before beginning your next project, or just want to spend a few hours looking over the countless inspiring photos of FTE members’ truck mods and customizations, you will always find a constantly-growing portfolio of knowledge, proven experience and invaluable connections and conversations. The forums cover every topic from Performance, Engines & Troubleshooting to how to maintain Older, Classic & Antique Trucks, and all of it will inexplicably help you keep your Ford truck in the best shape it can be. Plus,  the best part is that becoming an FTE member is free.
Check out our newest find from the forums, below, then sign up and join in on the conversation, meet some fellow Ford truck fans, and share your experiences regarding your favorite ride. You’ll be helping to keep the web’s greatest Ford trucks resource consistently updated while learning more about Ford trucks inside and out.
Thread of the Week: ’88 F-350 460 to 300 Six
OP: B1jetmech
Member’s Request: Will a 300 six frame perches work on a F-350 frame from an F-150?
“I picked up an 88′ F-350 2WD cheap,” writes B1jetmech. “It has a 460/C6 combo. My immediate plans are to swap in 300 six with either an E4OD (updated) or a M5OD (short term). The reason is, I’m averaging 8.6 MPG with the 460 and really don’t need that kind of a loss of fuel mileage for everyday driving. Plus, I just always liked the 300 six…and this is coming from a Chevy guy…LOL!
“So, getting into this kind of swap…My question is: Will the 300 six frame perches work on a F-350 frame that came off an F-150 frame (donor truck)?”
‘I’m averaging 8.6 MPG with the 460 and really don’t need that kind of a loss of fuel mileage for everyday driving. Plus, I just always liked the 300 six…and this is coming from a Chevy guy!’
Later, once he begins the project, the original poster of the thread discovers a problem. “I really never heard of a 300-6 block cracking,” says B1jetmech later in the conversation, “but if water freezes, it doesn’t matter what you have, it can destroy your engine.” However, despite the brief setback, it’s nothing that he can’t fix with a quick trip to a junkyard and some suggestions from his fellow FTE forum members.
FTE
Short, Sweet & to the Point:
“In quick summary: the 6s, 302, 351s all share most of the same components, including air filter box, etc.; the 460 had its own. So, you may have to address each component,” suggests Beechkid.
Experienced Advice:
“I am close to finishing swapping a 4.9l into a 1997 F-350 4×4 that originally had a 5.8l, and I kept the original E4OD tranny,” writes Senior Member BWD444. “I think the frames are similar, but not sure. But the 4.9l mounts should work and just bolt in; mine did. You will need a 4.9l PCM from anything 92′ to 94′, and if you use an E4OD, you will need one that had one of those along with the 4.9l engine. You will more than likely need to change the underhood wire harness. …I would suggest if the truck is already a manual tranny to stick with that as you will have more harness issues to go from manual to auto. Also be aware that after 94′ Ford changed the E4OD and moved some electronics from the tranny to the PCM, so do not use a 94′ PCM with a later tranny.”
Find the full Ford Truck Enthusiasts forum thread here and check out the progress that B1jetmech made on his truck, and see it in action via the awesome shots he shared of the project throughout the process.
See you in the forums!
Join the Ford Truck Enthusiasts forums now!
Comments ()
