rear dvd player problems
Old 10-19-2009, 10:07 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
there is a disc stuck on the rear dvd. the screen says bad disc and wont eject. how do i get it out?
Old 10-25-2009, 10:04 AM
MyViewGS's Avatar
MyViewGS
MyViewGS is offline
Mine is aftermarket and im sure it differs from yours but ...... try (with a helper) disconnecting its power supply then while pressing the eject button re-connect the power. If that doesnt work look for a "pin hole" near the DVD drive access door. Unfold a paperclip and insert into the hole GENTLY. The hole is a DVD drive latch release access BUT it can be very easy to damage the DVD drive and or its door latch assembly by trying this. The safe way is to take it to a tech.
MyViewGS
Old 10-26-2009, 12:34 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
well i figured it out. I took out the FES fuse to that it could reset the dvd system. After i put it back in i presed eject and the dvd came right out
Old 02-22-2010, 03:58 PM
Klute's Avatar
Klute
Klute is offline
Hey, I have a 2008 Exp and having DVD probs also. I do not have a listing for the Family Entertainment System (FES) fuse........which one is it? Where? What else would it be listed under? Thanks for any help!
Old 02-22-2010, 06:15 PM
berry1234's Avatar
berry1234
berry1234 is offline
Fuse #3. Send me a PM and I will email you the diagram.
Old 02-22-2010, 06:59 PM
Klute's Avatar
Klute
Klute is offline
I wasn't anywhere close to fuse #3. I checked 2 small fuses (#28 & 3?)both listed as radio under dash and then a cartridge fuse (big #) under the hood....the book listed it as rear control module. I need some diagrams cause I am going thru serious Sirius withdrawal!!! Ouch, sorry, my attempt at humor. My e-mail is linloo22003@yahoo.com......thanks so much
Old 02-22-2010, 07:04 PM
berry1234's Avatar
berry1234
Info sent.
Old 02-22-2010, 07:22 PM
Klute's Avatar
Klute
Klute is offline
Thanks, will try to figure it all out tomorrow and let you know how I made out. Sure has me bewildered!!!!! Since all was fine one minute then poof....nada.
Old 02-23-2010, 12:03 PM
Klute's Avatar
Klute
Klute is offline
That's all it took! The #3 fuse....thanks so much, saved me tons of money and aggravation I'm sure!
Old 03-02-2010, 07:10 PM
markt1993's Avatar
markt1993
markt1993 is offline
I'm have the same problem, could you email that to me too? markt1993@gmail.com
Thanks, mine was the same way was working perfect then my son decided to change disc and it won't come out. Now it won't play or eject. It also comes on and tries to eject even with the car off, in fact it has killed the battery twice.
Old 10-11-2010, 12:29 AM
Booya's Avatar
Booya
Booya is offline
Rear DVD System - DVD Stuck
I have an 2007 Expedition with an OEM rear dvd system, and it has a DVD stuck, my understanding is that I need to reset it to remove the DVD? any ideas how to remove it or reset it? can someone send me the fuse diagram please, ignore the post I fixed it.
Old 12-12-2010, 04:41 PM
expedition newbie's Avatar
expedition newbie
expedition newbie is offline
hi, I have a 2007 expedition EL and have the same problem with my rear dvd player. the disc is stuck inside and couldn't figure it out how to remove it because player is not responding with the eject button. I checked the fuse box already but wasn't sure which one is for the dvd player. Can you please also send me a copy of the fuse box diagram or electrical diagram? . Thank you very much. My email is ermin731@yahoo.ca
Old 12-13-2010, 05:32 AM
chuck s's Avatar
chuck s
chuck s is offline
Disconnect the battery negative and all power to the truck is cut. No wiring diagrams needed...
-- Chuck
Old 04-10-2012, 07:37 PM
ktaylor99's Avatar
ktaylor99
ktaylor99 is offline
2008 expedition dvd and sirius quit working
I have a 2008 expedition and suddenly the dvd player and sirius are not working...in reading thru some of the posts here it seems I may need to replace the #3 15 amp fuse...however, I can't find it! Does anyone have a diagram of where that particular fuse is located? thanks in advance!
Old 04-10-2012, 08:01 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Passenger side lower kick panel. Remove trim panel cover, then remove fuse panel cover.
Fuse #3 is third one down from the upper left corner.
p.s. It's in the owners manual page #304-305
Matt
Quick Reply: rear dvd player problems
