1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ading upfitter switches after purchase on a new 2009.
Old 05-05-2009, 03:04 PM
John7894's Avatar
John7894
John7894 is offline
How hard is it to add upfitter switches to a brand new 2009? I see it comes as a package with the heavy duty alternator when bought new.
Is the alternator necessary when adding it after purchase, or is it only needed when the switch output exceeds a certain amperage amount?
The truck I'm looking at was not built with the switches or heavy duy alternator. I'm only looking to run some backup lights and maybe an air compressor off of them.
Thanks,
Old 05-05-2009, 03:57 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
well, here is how to go about it:
1. Order from FTE/parts guy, he will send it out. comes with wiring, everything you need.
Th!nkPartsGuy/FTEPartsGuy or you can buy from whomever.
2. Use the following link for a nice diagram so you can find the plug and where to mount the module and run the wires: https://www.fleet.ford.com/truckbbas/non-html/Q157.pdf
Takes about a hour or so. Hardest part is getting your body to twist in ways it wasn't meant to.
Let us know how it goes.
Old 05-05-2009, 04:38 PM
John7894's Avatar
John7894
John7894 is offline
Thanks. I'm finding trucks that have the features I want except the upfitter switches. Just want to be sure it'll be an easy addition. Is it all plug and play? Or is there some splicing involved?
Old 05-05-2009, 04:48 PM
senix's Avatar
senix
senix is online now
plug and play, just follow the diagram
Old 05-05-2009, 06:05 PM
deadbug's Avatar
deadbug
deadbug is offline
Hey senix,
That's a great response,
all the links and info right as his finger tips
Old 05-05-2009, 07:50 PM
senix's Avatar
senix
senix is online now
we aim to please
Old 05-13-2009, 04:20 AM
Sparkinak's Avatar
Sparkinak
Sparkinak is offline
I added the switches to mine and you aren't kidding about bending and twisting in ways your body wasn't designed. I finally found the pigtail needed. Stuck my arm up and when it came back down it was red. I was relieved to see I finally got it plugged tho. It was a chore to find thats for sure. But great add and would do it again in a heart beat.
Old 05-13-2009, 08:01 AM
rgrat1618's Avatar
rgrat1618
rgrat1618 is offline
Do you have the part number for the upfitter switches kit? I have a 2008 F250. Also looking for a fog light kit.
Rob
Old 05-13-2009, 08:20 AM
caprang's Avatar
caprang
caprang is offline
Just to add more infor to what Senix already posted......
I dont know if its the same part number with FTE parts guy but you can also look here...
Your Premiere Source for Ford Truck Parts and Accessories
And their instructions......
They added the heavy duty alternator on the 09 models. Ford has been using the upfitter switches since 05 without the heavy duty alternator requirement. Unless you are running something with a lot of draw you will be just fine. I run some lights, the high idle mod, and my CB and only have the standard alternator.
Old 05-13-2009, 12:50 PM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
Moved to Super Duty
Old 05-13-2009, 06:25 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
FTE/PARTS-GUY is offline
Former Vendor
follow the link
Ed
Old 06-03-2009, 11:30 PM
DingDangIt's Avatar
DingDangIt
DingDangIt is offline
Great info on this thread & exactly what I was looking for. Ordered the upfitter switches & rep points for senix.
Thanks!
Old 06-04-2009, 05:00 AM
senix's Avatar
senix
senix is online now
you will have to wait to order from the parts guy, he is in between jobs at the moment.
Old 06-11-2009, 05:04 PM
senix's Avatar
senix
senix is online now
Thanks!
Thanks for rep.
Old 06-11-2009, 08:12 PM
DingDangIt's Avatar
DingDangIt
Originally Posted by senix
Thanks for rep.
You bet! I received the kit but there's no instructions. I guess it will be self expanitory when I dig into it.
Eric
Quick Reply: Ading upfitter switches after purchase on a new 2009.
