Hellwig Helper Springs/Add-a-leaf
Old 11-12-2000, 05:19 PM
metroplex's Avatar
metroplex
metroplex is offline
Are Hellwig Pro-Load helper springs good?
Which should I get, the progressive or constant rate springs?
One side of my E-150 is leaning, so I'm getting a new leaf spring from JC Whitney to replace the malfunctioning spring. I'm then getting helper springs, but I want something that will give me a slightly stiffer ride but has to be HD enough to help carry cargo.
-Charlie
1981 Ford Thunderbird "GT", 5.0L, AOD, 2-bbl (soon to be 347 stroker w/ 400 rwhp)
1989 Ford E-150 Cargo Hauler, 4.9L I6, C6
2000 Ford Crown Victoria PI, 4.6L SOHC V8, 4R70W, 3.55s, Dual Exhaust, Go Rhino Push Guard, Steel rims with Type 170 center caps, Dunlop SP5000 Sport Ultra High Performance All-Season Tires
Old 11-22-2000, 08:24 PM
5 Star Tuning's Avatar
5 Star Tuning
5 Star Tuning is offline
Former Vendor
Hey there, i just installed the Roadmaster active suspension system on my big 85 bronco and i can say i think i made the best choice because i almost went with Hellwig.
check it out www.activesuspension.com/
Hope this helps,
Mike
Old 11-27-2000, 06:03 AM
Nathan's Avatar
Nathan
Nathan is offline
Old 03-26-2017, 08:08 AM
pancake52's Avatar
pancake52
pancake52 is offline
Question hellwig helper springs? sagging on rear leaf?
the rear end of my 1998 low top conv e150 seems to sag. I like the ride but came across this option and wondered if someone has added hellwig helper springs.. I had planned on adding a leaf to the rear springs but this may be easier way to go. Will this raise the rear end ? what does it do to the ride?
Old 03-26-2017, 11:44 AM
Conanski's Avatar
Conanski
Conanski is offline
I put a set of Helwig EZ990 springs on my F150 and I thought they did a great job, they definitely improved stability and load carrying capacity but didn't affect unloaded ride.
Old 03-26-2017, 12:56 PM
pancake52's Avatar
pancake52
helwig?
would the Helwig EZ990 springs raise up the rear end also ?
Old 09-20-2017, 04:51 AM
pancake52's Avatar
pancake52
anyone have an update as to the hellwigs . will these raise up the rear and un-arch my original springs which sag?
Old 09-22-2017, 02:23 PM
maples01's Avatar
maples01
maples01 is offline
Uh, this will aid in stopping sway, but will NOT correct a worn leaf pack, you need to replace the rear pair of leaves, not just one side, they are worn, a spring shop could do it, if you are lucky enough to have one. I have this issue on my 73, my wheelchair lift sped it on it's way after just one year, the van was 40 years old tho, I am rebuilding both packs.
Old 04-07-2018, 11:31 AM
Ken Meuer's Avatar
Ken Meuer
Ken Meuer is offline
Ordered Hellwig helper springs over 30 days ago. HELLwig.. had told me on several occasions that they would be shipping them that week. Long story, I am concealing the order and looking for something else. HELLwig has been Hell to work with. In my opinion I would/will never order another HELLwig product.
Old 04-07-2018, 04:37 PM
Clubwagon's Avatar
Clubwagon
Clubwagon is offline
I bought a set of add-a-leaf helper springs at Autozone. It was several years ago and I don't know that they are still available or not. They worked great on my '96 E150 Clubwagon.
Old 04-25-2018, 08:48 AM
pancake52's Avatar
pancake52
More info on your add a leaf pls
Did the AutoZone add a leaf stiffen up the ride? Raise the rear at all?
Old 04-25-2018, 11:53 AM
Clubwagon's Avatar
Clubwagon
Yes. Slightly.
I used my van to tow and put a lot of equipment in the back. I was looking at a way to reduce the squat from the load. It worked very well. Ride was good also.
I also fitted a Helwig front swaybar along with the rear springs. The combination made the van ride and handle much better.
Old 04-25-2018, 01:57 PM
pancake52's Avatar
pancake52
Add a leaf model number
Thanx I will probaby go that route. Any model number / brand you might have would help me decide what to buy.
Old 05-01-2018, 11:40 AM
Clubwagon's Avatar
Clubwagon
Sorry, but its been years since I did this. Bought the ban in '96 and did the upgrade within the year. Any similar should work well. Also, a shock upgrade works well on these vans.
Eric0486
13
01-02-2018 08:09 PM
philbert49
1999 to 2016 Super Duty
08-25-2017 11:17 AM
191124x7
2017+ Super Duty
01-27-2017 01:15 PM
191124x7
2017+ Super Duty
01-17-2017 07:55 PM
motorsportsaddict
Ford Truck Parts for Sale
04-23-2016 11:03 AM
Quick Reply: Hellwig Helper Springs/Add-a-leaf
