List of acronyms used here on FTE
Old 12-08-2005, 09:05 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Here's a list of commonly used acronyms that are used. I'm making it sticky so it will be easily accessed by all who may be needing to know.
If any one of you find that an acronym is missing please post.
https://www.ford-trucks.com/forums/s...d.php?t=103441
Old 12-08-2005, 03:18 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
this site is totally diesel related, Steve Baz did a great job.
http://pages.prodigy.net/stevebaz/_i...az/index3.html
Old 12-16-2005, 02:33 PM
GigAg04's Avatar
GigAg04
GigAg04 is offline
Two that aren't on the FTE one:
HPOP and GPR.
Other than that it looks real good!
Old 02-23-2006, 12:29 AM
The Blue Pearl's Avatar
The Blue Pearl
The Blue Pearl is offline
Ty very much for these. It will help me understand better.
Old 02-25-2006, 10:29 AM
Customz's Avatar
Customz
Customz is offline
He forgot BSEG!
Old 03-18-2006, 08:02 PM
the1mg's Avatar
the1mg
the1mg is offline
Question
How about IMHO
Old 03-23-2006, 03:44 PM
ssnh's Avatar
ssnh
ssnh is offline
MBRP had me perplexed when i first came here - http://www.mbrp.com
Old 05-16-2006, 11:08 AM
Ford RV'er's Avatar
Ford RV'er
Ford RV'er is offline
I have come across a few acronyms and definitions that I need some help with;
CPS,CCV Mod, MAP Regulator, BTS Valve Body, DP Tuner, WW, AIH, MBPR, HPX, AIS, EBPV Delete Pedestal, DI Turbine Outlet.
I'm a newbie and not familiar with these terms. Any help would be appreciated.
Many thanks.
Old 11-11-2008, 07:57 AM
krejci.mike's Avatar
krejci.mike
krejci.mike is offline
what is RHN?
Old 11-11-2008, 08:06 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Originally Posted by krejci.mike
what is RHN?
The Roadside Help Network.
See here: https://www.ford-trucks.com/forums/7...e-new-rhn.html
Old 11-11-2008, 09:25 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Many thanks.
Here's some info:
CPS = cam position sensor - more reading on that: Welcome to guzzle's CPS R&R Web Page
CCV Mod = CrankCase Vent mod - to clean up your intercooler tubes from the oil from the crankcase ventilation of the stock setup of the truck - Welcome to guzzle's CCV mod web page
BTS Valve Body = BTS stands for Brian's Truck Shop - Brians Truck Shop - He's a custom builder of trannys and components for our PSD's, awesome stuff. Here's a write up on the install: Welcome to guzzle's BTS Valve Body Web Page
DP Tuner = DP TUNER custom burn tuners for our PSD's.
WW = Wicked Wheel - Turbo wheel mod to the early '99 style wheel to help with surge. More reading and link: http://www.dieselsite.com/index.asp?...PROD&ProdID=47
AIH = Air Intake Heater - a cheap mod to remove the Air Intake heater from the intake to help with airflow. Not really needed for our trucks. Does not help with starting system or related to glowplugs. More reading and link: http://www.dieselsite.com/index.asp?...PROD&ProdID=48
MBRP = Manufacturer of exhaust products MBRP Inc Performance Exhaust - Snowmobile, Diesel, Muscle Car, Exotic, Motorcycle and Sport Truck Exhaust Systems.
HPX = High Pressure Crossover line - mod to equalize the oil pressure in each head to help with injector efficiency and smoother idle: KCM S.S. HPX Line (99-03)
AIS = Ford Severe Duty Air Intake System - very nice replacement intake for your truck with OEM looks. Huge upgrade over stock and way better filtration: 1999.5-2003 7.3L Ford Powerstroke Severe Duty Air Intake System AIS FA1759
EBPV Delete Pedestal= turbo pedestal that has no boss for the exhaust backpressure valve. http://www.dieselsite.com/index.asp?...ROD&ProdID=237
Old 01-28-2016, 02:26 PM
FluffyTheTreeCutter's Avatar
FluffyTheTreeCutter
FluffyTheTreeCutter is offline
uvch?, 50 cent mod
Old 01-28-2016, 02:31 PM
HKusp's Avatar
HKusp
HKusp is offline
Are you asking what they are, or do you want them added to the acronym list?
Old 01-31-2016, 08:10 PM
FluffyTheTreeCutter
I just dont know what the acronym stands for. Oh wait under valve cover harness?
Old 01-31-2016, 08:47 PM
varminthunter243's Avatar
varminthunter243
varminthunter243 is offline
Yessir. And the 50 cent mid pertains to cutting a little bit off of a quarter and using it to stabilize the injector harness plugs on each head. 1 quarter per head, hence the name. Took me a long time to get alot of these figured out too haha
Quick Reply: List of acronyms used here on FTE
