1972 F250 Sport Custom LB SC
A few questions for my new acquisition please. (well maybe more than a few )
The Truck has been rebuilt, engine and drive train. I plan to finish the restoration.
1. Has anyone installed an aftermarket cruise control on a '72 F250? If so can you tell me which one? (live in a rural area, long drives to nowhere)
2. I'm getting to paint it the original colors (2 tone) I've been quoted about 4 to 5k just to start, (pro shop) is that about right? No dents or rust that I can see.
3. The bed is not in bad shape ether, I'm thinking of a spray in bed or is it better to paint it and use a mat?
3. I plan to polish the anodized aluminum trim (no dents but looks real bad ) is that wise?
Lastly can you buy a hard bed cover for this truck?? Having problems finding one.
Thanks for your help
First off welcome to FTE. Paint can get expensive. There's a lot more than just putting the color on. Like they say 95% body work, 5% spraying. If you're going 2 stage, base coat / clear coat depending on brand the paint alone could be $1000.00 . As for the bed floor that's personal preference. What do you plan on using the truck for? If you're hauling stuff then Berliner would be OK, otherwise a nice painted bed that you put a mat in is my vote. The trim can be polished up nice.
Welcome to the FTE Forum!! Have you looked at: National Parts Depot, MacsAutoParts.com, LMCtruck.com or Summit racing for your needs? Also be sure to check out :Read First: Technical Info Hyperlink Compilation ( 1 2) HIO Silver, at the top of the forum page
Good advice above.
I would add that polishing your aluminum trim will be pretty involved. The anodizing is a pretty tough surface and should be stripped. I did my headlight bezels with caustic soda (sodium hydroxide, found in crystal drano) and it worked well, but it's tricky and dangerous stuff. Then sand and polish, polish, polish, polish...
Welcome to the forum, this is a great bunch here. Post pics of your truck.
The Drano worked, and FAST, so be careful not to dissolve your trim.
It will eat skin and blind you if you get it in your eyes, so wear chemical resistant gloves and a face shield.
Here's a pretty good thread on the subject: https://www.ford-trucks.com/forums/1...storation.html
Sounds good
Looks good, I'll try a small spot first on old left over molding. I was a chemical process operator/foreman for 30 years so I know what you're saying. I've decided to buy a new molding set for 500 bucks, och! since they will take them all off for painting anyway I'll have them replaced with the new ones. Keep the old ones for spares. However the grill and such I'll do myself. It has a funky looking rear step bumper with wielded on receiver that use to be silver. It is a strong bumper though. I'll try new paint (black or body color maybe?) but I like the regular chrome rear bumper or pan no bumper. We'll see. The truck colors will be gold-ish over pearl white sides and cab roof.
Thanks
Thanks
on
Welcome to the best Bumpside kingdom.
Well, I installed a cruise control unit in my 5 speed stick trans. It's all a electronic unit now days no more vacuum units like back in the day.
It's fairly easy if you can follow instructions an have some what smarts of how to logical thinking.
To make it easy get the drive line magnetic pickup sensor unit.
I wiped out the driveline sensor unit cause the plastic tie-wrap came loose.
So my fix was JB weld epoxy the magnet onto the driveline and used a regular tie wrap to hold it in place.
Orich
Got this unit from Summit it's a universal add on unit.
Orich
What color
I was going to get a chrome bumper to replace my industrial strength step bumper, (Man that thing is massive and U GA LY) but money is getting in the way. Maybe later. It use to be silver, can't decide what color to paint it. I found a speckle kind of dimple look silver paint that may look nice or just paint it black, maybe even body color. Any suggestions?
Orich
Orich
Rally Wheel Paint Silver Aerosol 12 oz
