Crown Vic 4 wheel disc brake conversion
I have done the Crown Vic front end swap and the crown Vic 8.8 rear swap....all went very well , now doing brake lines
I have mounted the Crown Vic booster and master cyl also but the car had antilock brakes and no proportioning valve
For those that have done this swap what proportioning valve did you use for a 4 wheel disc brake setup?
I have read that some didn't use one which makes no sense as you need a distribution block of some sort to run the lines from the master cyl
Any advise would be welcome
Thanks!
Thanks!
F100-1969
37
03-31-2018 10:25 AM
