20mm or 18mm dowel motor?
Can someone tell me if this motor is 18 or 20?
1FTSW21P06EA55574 is the vin. Chassis was built in 6/5, but the motor has 2006 on it.
Thank you for any help.
Here's the bulletin to help you understand it all.
Technical Service Bulletin: Ford Powerstroke 6.0 L - Service Remanufactured Engine, Cylinder Block, and Cylinder Head Identification - Hot Shot's Secret®?
I thought commonized heads were designed to fit earlier models as well as later models, i.e. would work for both with appropriate dowels/adapters. Am I wrong here?
When I replaced the heads on my 05 6.0, that is what I was led to believe, that the communized heads that I received were not only better than cracked heads, but also considered to possibly be an upgraded newer design. Was I buffaloed? (BTW, they were ordered as "rebuilt" but came in boxes from International labeled as "new part".)
I thought commonized heads were designed to fit earlier models as well as later models, i.e. would work for both with appropriate dowels. Am I wrong here?
The OP is questioning his so he can order the correct kit, 20mm or 18mm.
Thanks for the help!
My truck was built in January of 2006, I ordered what the tech thought was the correct dowel sized gaskets (I assume the 20mm, but that was 4 years ago), but they weren't. It cost me another set of headgaskets as my buddy had slightly opened the packaging. Not enough to remove any parts, but I was denied a refund based on that.
My point is that I would check everything I possibly could before ordering.
Sean Smith
1999 to 2016 Super Duty
24
05-29-2019 06:30 AM
82-100
15
04-28-2009 08:29 AM
