Question about carburetor part
Received 4,132 Likes
on
on
on
on
If it isn't raising your idle for A/C just run it without and see if you develop a stalling issue. The one on my Toyota is on a fuel injected engine and without it in place the computer had issues over correcting when letting off the throttle fast. Kind of like a shock absorber for the throttle. May not be an issue on a carburetor. Look how many don't have one.
As far as testing it a Mity-Vac should work to see if it moves or leaks. I don't know if your would be directly ported to manifold.
A lot of those are anti-dieseling solenoids. The vacuum holds the plunger back and when you shut off the engine, no vacuum and the plunger goes out pushing the throttle open to prevent the engine from running on (dieseling). The ones that slowed return to idle typically have no vacuum port or electrical, just a light spring to allow slow return to idle. The electrical ones are typically used for the AC when the AC got energized so did the coil to hold the idle up so the compressor drag would not kill the engine.
You should not need it but if it holds vacuum you could use it hooked to manifold vacuum and set just below the linkage under vacuum so when the engine is shut off the plunger extends pushing the linkage.
Like others mentioned, some engines would stall when returning to idle. However, it is just as much an emissions part. When quickly returning to idle high intake manifold vacuum creates an extremely rich A/F mixture for a few seconds. So, slowly returning to idle minimizes that time period of a rich A/F mixture. If it were my motor, I would remove it, drive it and see if there are any issues.
on
Christian's1988Ford
17
01-11-2023 04:57 PM
packrat56
03-10-2017 08:27 PM
treese17
57
02-25-2016 10:48 PM
benbuilder
08-19-2015 05:45 PM
