what is the name of that non-hardening clay-like, sealing material?
I'm looking for that material used to pack in around the firewall opening where the heater core tubes come through. It was also used to seal the evaporator housing halves together, and other such uses.
It is like a non-hardening "clay-like" material. A little sticky. Like play-dough for those old enough to remember that stuff.
I bought some twenty-something years ago. I recall that that is sold in a flat package where the clay-like material was in cut into 6 or 8 inch strips laid out side-by-side about 10 strips wide. I think it was a 3M product. It probably comes in a roll too.
IF I could describe/name it correctly for Google, I'm sure it is still available.
Thanks
Thanks
I think I found it. After posting here I went to body shop supply website and scrolled through all the 3M products. This is what I'm talking about.
3M Strip Calk 08578
3M Strip Calk 08578
Go to Home Depot, Lowes or any electrical supply house and get Duct Seal. You can grab a chuck of it and stuff it in anywhere. You can also take a chunk and roll it between your hands until it is long and thin to sandwich between two halves of something.
Gardner Bender 1 lb. Plug Duct Seal Compound-DS-110 - The Home Depot
"dum dum", or "dub dub", is what we called it. It also works good when you have plastic dash panels that rub together, and squeak.
CamoF-250
01-17-2019 10:28 AM
madpogue
05-31-2016 07:02 AM
tumbleweed2
01-17-2008 09:44 PM
