Better check your power steering fluid!
I gotta admit,I don't check it very often. As long as I see no leaks or don't hear noises,I seldom think about it.
Not anymore! I just happened to check it and it looked like strawberry milkshake in the reservoir!
I know, you're thinking water in it,right? NOPE! Apparently it's a result of me adding a little power steering conditioner months before.
So I spent this evening with 3 qts. of type F running it and sucking it out, refilling,running and sucking it out,until I'd used all 3 qts.
Looks a LOT better now, BUT I'M KEEPING an eye on it from now on. don-ohio
There's nothing says that soup can couldn't be painted to prevent it from rusting.
Thanks for the tip sittinguy. I'll start using one. Never gave it a thought about the cowl drain dumping on the PS cap. When I saw my PS fluid boiling the water out on a hot summer day, I chalked it up to some dummy putting water in there. Now I know where it came from and how to keep it out of there.
cdunn
1983 - 2012 Ranger & B-Series
11-22-2004 07:43 PM
greasymonkey
19
03-02-2004 12:38 PM
